Differential Pressure Sensor - No Access
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Uwe
Post31-10-2018, 19:05    Subject: Differential Pressure Sensor - No Access Quote
"Pressure sensor replaced, attempted to calibrate it. Errors have been cleared. After entering the specified code, I always get "access denied." What am I doing wrong?"
Vehicle BMM.
Kundenservice bedeutet bei Audi, die Kunden so schnell ĂŒber den Tisch zu ziehen, daß sie die ReibungswĂ€rme als NestwĂ€rme empfinden!
Translated on 24-09-2026, 10:41.
Post01-11-2018, 11:03    Subject: Differential Pressure Sensor - No Access Quote
Please provide an Autoscan, Screenshot(s), and a description of the steps you took, in order.
Translated on 24-09-2026, 10:42.
Uwe
Post02-11-2018, 20:46    Subject: Differential Pressure Sensor - No Access Quote
Sorry for the missing colons, etc., due to a foreign keyboard.
My approach.
Errors cleared, no errors present. Ignition on, engine off, VCDS has connection. Entering coding II 11, entering login code 30605, error message.
Login rejected, invalid value range, error 31.
appears
The sensor was temporarily replaced for testing, and it now shows an error again during the vehicle scan. A different, clean sensor was used during the calibration attempt.
Autoscan.
Friday, November 2, 2018, 7:28:35 PM: 00397
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 18.9.0.2 HEX-V2 CB: 0.4436.4
Data as of: 20181004 DS296.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: TMBGE61Z962226440. License plate: [Missing information - please provide the license plate number].
Vehicle type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 69 72 76
77 7D
Mileage: 327,860 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: Error 0010.
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: DRV\03G-906-021-BMM.clb
Part number SW: 03G 906 021 GD Hardware:
Part: R4 2.0L EDC G000SG 8484
Revision: --H02--- Serial Number: SKZ7Z0E3357007
Encoding: 0000072
Operating number: WSC 11111 111 11111
VCID: 678A4B8D936DCCEF3FF-8032
"One error found:"
001688 - Reference voltage for sensor, 3/C.
P0698 - 000 - Voltage too low - Warning light ON.
Environmental conditions:
Error status: 11100000
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 327,863 km
Time: 0.
Date: 2000.00.00
Time: 19:25:05
Speed: 0 RPM.
Speed: 0.0 km/h
Binary value: 00100000
Binary value: 00000000
Readiness: 0 0 0 0 1 0
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AA, Hardware: 1K0 907 379 AA.
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0006786
Operating number: WSC 73430 790 00000
VCID: 71BE25D5ADA9025F61B-8024
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 1Z0 907 044 J
Component: Climatronic PQ35 084 0305
Operating Number: WSC 00000 000 00000
VCID: 3D26C9E5A171B63FB53-8068
Address 09: Central Electronics Label file: .DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 E, HW: 3C0 937 049 E.
Component: On-board network module H37 1002.
Revision: 00H37000 Serial Number: 00000003908076
Encoding: E18A8F130004140000110D000000000000087F065C
VCID: 2B02F7BD4F05288F1B7-807E
Subsystem 1 - Part number: 1Z1 955 119 A
Label file: DRV\1KX-955-119.CLB
Component: Wiper SK351 012 0401.
Encoding: 00065525
Subsystem 2 - Part number: 1K0 955 559 T
Label file: DRV\1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Encoding: 00208933
"One error found:"
01504 - License plate illumination (X)
012 - Electrical fault in the circuit - Intermittent.
Error status: 00101100
Error priority: 2
Error frequency: 2.
Lost Count: 107
Mileage: 327416 km
Time: 0.
text
aus
text
out
Voltage: 11.90 V
text
aus
text
out
one
text
aus
text
out
text
from
text
from
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 S, HW: 1K0 909 605 S.
Part: Q2 AIRBAG VW8 026 0800
Revision: 09026000 Serial Number: 0038ND0VR66V
Encoding: 0020786
VCID: 3C20C4E1BA6BBF3782D-8068
Subsystem 1 - Serial number: 6332MSME0E7517409.
Subsystem 2 - Serial number: 6342MSME0F3F1830H
Subsystem 3 - Serial number: 6351HSME0934223D3
Subsystem 4 - Serial number: 6361HSME09340E79E.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AG, Hardware number: 1K0 953 549 AG.
Component: J0527 034 0070
Encoding: 0002042
VCID: 77AA1BCDC3CD5C6FAFF-8022
Subsystem 1 - Part number: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 1Z0 920 841 E
Component: COMBINATION INSTRUMENT VD1 0920
Encoding: 0005101
Operating number: WSC 24448 002 1048576
VCID: 3828D8F18E539317665-806C
Address 19: Diagnostic interface
Label file: .DRV\1K0-907-530-V1.clb
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120
Revision: H10
Serial number: 28001061220238
Encoding: 7D3F4FC8072302
VCID: 2A0CF2B940FF3187E01-807E
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO VD1 0920
Address 37: Navigation
Label file: DRV\1T0-919-887.lbl
Part number: 1Z0 919 887 B
Component: Navigation 0412
Encoding: 0000002
VCID: 47CAAB0DF3ADECEF1FF-8012
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN2.lbl
Part number: 1T0 959 701 B
Component: Door Seal 024 2345
Encoding: 0000246
VCID: 3634D6C984476567749-8062
"One error found:"
00932 - Power window motor, driver's side (V147)
005 - No or incorrect initial setup/adaptation - Intermittent.
Address 44: Steering Assist
Label file: DRV\1Kx-909-144-G2V2.clb
Part number: 1K1 909 144 K
Component: EPS_ZFLS, Size 5, Part Number D06 1701.
VCID: 3332EFDD9735704F537-8066
Address 46: Comfort System. Label file: .DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AK
Component: KSG 0401
Encoding: 00D002007F2D8505484FC61004CC
VCID: 79AE1DF5F5D94A1FD9B-802C
Subsystem 5 - Part number: 1Z0 951 171 A
Component: Tilt Sensor 008
Encoding: 00000000
Operating number: WSC 00000
Subsystem 6 - Component: Sounder, No Answer.
Subsystem 7 - Part number: 1Z0 951 171 A
Component: Interior monitoring 008.
"One error found:"
01134 - Alarm horn (H12)
004 - No signal/communication.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN2.lbl
Part number: 1T0 959 702 B.
Encoding: 0000246
VCID: 372ADBCD834D9C6F6FF-8062
Address 55: Headlight range adjustment.
Label file: DRV\1T0-907-357.lbl
Part number: 1T0 907 357.
Component: Dynamic LWR 0003.
Encoding: 0000007
VCID: 74B02CC1D2BB37778AD-8020
Address 56: Radio
Label file: DRV\1T0-035-095.lbl
Part number: 1T0 035 095.
Component: Radio 0412
Encoding: 0004400
VCID: 6B8237BD8F85E88F5B7-803E
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E
Component: Door seal 021 2435
Encoding: 0000144
VCID: 323CEAD9682F7947581-8066
Address 69: Trailer
Label file: DRV\8P0-907-383.lbl
Part number SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Encoding: 0000001
VCID: 76B416C9C4C72567B49-8022
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
Address 76: Parking Assist
Label file: DRV\1Z0-919-283.lbl
Part number SW: 1Z0 919 283 C. Hardware: 1Z0 919 283 C.
Component: Parking Assist System, 8-Channel, Part Number H04 0020.
Encoding: 0010001
VCID: 3E24CEE9AC77AD27AC9-806A
Address 77: Telephone Label file: DRV\5P0-862-335.lbl
Part number SW: 5P0 862 335 B, HW: 5P0 862 335 B.
Component: FSE_2P5x H21 0060
Revision: 00000001 Serial Number: 00000000391371
Encoding: 0000411
Address 7D: Auxiliary Heater
Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00900000 Serial number:
VCID: 2D06F9A5711126BF053-8078
End--(Duration: 01:29, Battery voltage start/end: 11.9V/11.9V. VIgn 11.9V)---
Translated on 24-09-2026, 11:12.
Post04-11-2018, 22:25    Subject: Differential Pressure Sensor - No Access Quote
"It contains everything about it."
1 error found:
Error priority: 0.
Error frequency: 1.
Lost counter: 255
Mileage: 327,863 km
Time: 0.
Date: 2000.00.00
Time: 19:25:05
Faulty engine control unit or wiring problem (short circuit)... the error is the issue.
Translated on 24-09-2026, 11:44.
Uwe
dieselschrauber likes this.
Post10-11-2018, 13:15    Subject: Differential Pressure Sensor - No Access Quote
Okay, the new sensor is installed.
The old part was defective. Initially, a new part was purchased, but it was also defective. The errors that appeared in the initial car scan were obviously caused by the defective sensor and were not pre-existing issues. The errors have been cleared and will not reappear.
The new Autoscan is attached below. The problem with pairing remains. Ignition on, engine off. 1st attempt: code entered, error 31 appears.
Does the sensor even need to be calibrated? By repeatedly turning the ignition on and off, the differential pressure is now at zero. Previously, the offset was significantly out of range, but it appears to have now been corrected. The engine is running, but hasn't initiated a new regeneration cycle yet due to the low mileage. The values are plausible.
Saturday, November 10, 2018, 11:51:09:00397
77 7D
Mileage: 328,030 km
01-Motor electronics -- Status: OK 0000
Encoding: 0000072
Revision: 00H13001
Coding: 0006786
Encoding: 00065525
Encoding: 00208933
"One error found:"
012 - Electrical fault in the circuit.
Error status: 01101100
Error priority: 2
Error frequency: 4
Lost Count: 71
Mileage: 327416 km
Time: 0.
text
aus
text
out
Voltage: 11.90 V
text
aus
text
out
one
text
aus
text
out
text
from
text
from
Address 15: Airbag
Encoding: 0020786
Encoding: 0002042
Encoding: 0005101
Revision: H10
Encoding: 0000002
"One error found:"
02731 - CD reading error.
001 - Upper limit exceeded.
Encoding: 0000246
"One error found:"
Component: KSG 0401
Encoding: 00000000
2 error codes found:
00323 - Vehicle tilt sensor (G384)
008 - implausible signal - sporadic.
Encoding: 0000246
Encoding: 0000007
Address 56: Radio
Encoding: 0004400
Encoding: 0000144
Address 69: Trailer
Encoding: 0000001
Encoding: 0000144
Encoding: 0010001
Encoding: 0000411
End -------- (Duration: 01:31, Battery voltage start/end: 12.2V/12.3V) --------
 File size:  186.23 KB
 Viewed:  4291 times
Translated on 24-09-2026, 12:15.
Post10-11-2018, 17:41    Subject: Differential Pressure Sensor - No Access Quote
Translated on 24-09-2026, 12:45.
Uwe
Post11-03-2019, 12:26    Subject: Differential Pressure Sensor - No Access Quote
"We've already installed the third differential pressure sensor, a Bosch unit. It worked for a few weeks, and now it's failed again. We also replaced the wiring to rule out any loose connections outside of the sensor itself."
The problem was that it started regenerating prematurely, but unfortunately, the process didn't complete. A check revealed an error code from the sensor and implausible values. So, I installed a new one, cleared the error codes, and calibrated it by turning the ignition on and off. Now it shows zero when the engine is off, and it's providing plausible and stable values otherwise.
Okay, so the DPF light is still on. This means it's trying to complete a regeneration cycle. Ironically, it's not actually regenerating. How do I get the light off? Should I force a regeneration?
Translated on 24-09-2026, 12:47.
Post11-03-2019, 18:20    Subject: Differential Pressure Sensor - No Access Quote
The question is, why is your differential pressure sensor constantly failing?
What is the exact error message?
Short-term defects can only be caused by excessive pressure differences.
Is the engine control unit software original, or was it installed by a third party using DVDs from eBay?
Have you already compared the values of your car with those in the following topic?
Translated on 24-09-2026, 12:48.
Uwe
Post12-03-2019, 0:27    Subject: Differential Pressure Sensor - No Access Quote
The first replacement sensor arrived defective. The second one was a cheap part and failed after only a few weeks. Then I tried another Bosch sensor. When that one started acting up, I checked the wiring. The connector looked slightly corroded on the surface. However, there was no short circuit and no dirt on the contacts. Nevertheless, I replaced the entire wiring harness to be on the safe side.
The pressure sensor is broken again. The readings are going haywire, and an error code has been stored. Since I already replaced the sensor, the error message wasn't saved; I just cleared it.
The filter seems to be full. The mileage is unclear due to the car being a used purchase. However, a new DPF is already here and just needs to be installed in the car.
"Still, thank you for the helpful link. I was already familiar with that topic. My BMM engine has extremely temperature-dependent differential pressure values. After driving with a heavy load, I get around 330 mbar, otherwise not even 300. At idle and under partial load, everything is within the normal range."
And yes, the car has a chip tuning system that I've been using for almost 200,000 kilometers, and so far it has been working fine, with no issues other than the pressure sensor defect. I don't think this is the problem.
Translated on 24-09-2026, 12:50.
Post17-03-2019, 14:03    Subject: Differential Pressure Sensor - No Access Quote
At over 200,000 km, your DPF may be excessively full, and under certain operating conditions, the pressure difference at the sensor may be too high.
If you want to continue driving the car for a longer period, I would recommend cleaning the DPF (Diesel Particulate Filter).
"Are there also companies that offer cleaning services?"
Translated on 24-09-2026, 12:52.
Uwe
Post18-03-2019, 9:31    Subject: Differential Pressure Sensor - No Access Quote
Uwe wrote:
A new DPF is already here and just needs to be installed in the car.
Due to a lack of time, the DPF is still lying around here, but it will be installed in the car soon icon_wink.gif.
I measured the differential pressure again. It reaches up to 290 mbar even with a warm filter, not 330 mbar as mentioned above.
The issue with the lights has resolved itself. The DPF light was on due to the previous history, but there was no regeneration occurring. Apparently, the control unit needs more time to accept the now-clean differential pressure values.
Translated on 24-09-2026, 12:54.
Uwe
Post03-05-2019, 16:05    Subject: Differential Pressure Sensor - No Access Quote
The DPF is installed and working. However, that's not the issue we're discussing.
My VCDS software cannot access some control units in two vehicles. I receive the error message: "Control unit does not respond." However, the control unit is installed, and sometimes I can access it intermittently. The engine control units are always accessible. This is also consistent with the fact that I cannot access the pressure sensor.
Is it possible that the cable is defective, or could it be my computer running Windows 7?
Translated on 24-09-2026, 12:55.
Post03-05-2019, 17:30    Subject: Differential Pressure Sensor - No Access Quote
Please perform a full scan of the vehicles, as some control units may be unresponsive. Only then can we provide more information. Some antivirus programs may also temporarily halt the system, which can lead to connection problems.
Both the connection of the diagnostic cable from the laptop to the vehicle and its power supply can also cause problems.
It is always important to provide a description of the error that is as accurate as possible, along with the relevant context and conditions.
Translated on 24-09-2026, 12:56.
Uwe
Post03-05-2019, 20:03    Subject: Differential Pressure Sensor - No Access Quote
Two cars, split into two separate posts for better clarity.
He experienced the problem with the differential pressure sensor as described earlier, which could also have been resolved through other means. I still cannot access or adapt the function via VCDS.
The steering and braking electronics were temporarily unresponsive, and the control unit is not responding.
Access via laptop, battery operation, no antivirus software, no other use besides VCDS. The battery is so good that it could power a Tesla icon_smile.gif.
Friday, May 3, 2019, 7:56:07 PM: 00397
License Plate: OCTI
Mileage: 344,440 km. Repair order:
77 7D
Mileage: 344,440 km
08-Climate Control/Heating Unit -- Status: Error 0010.
42-Door Electric Driver -- Status: OK 0000
Encoding: 0000072
Revision: 00H13001
Coding: 0006786
"One error found:"
00229 - Refrigerant pressure.
002 - lower limit exceeded.
Encoding: 00065525
Encoding: 00208933
"One error found:"
02395 - Lamp for front right side marker light (M3).
Error priority: 2
Error frequency: 1.
Lost Count: 46
Mileage: 344,445 km
Time: 0.
one
Voltage: 11.75 V
one
one
text
aus
text
out
text
from
text
from
Address 15: Airbag
Encoding: 0020786
Encoding: 0002042
Encoding: 0005101
Revision: H10
Encoding: 0000002
Encoding: 0000246
Component: KSG 0401
Encoding: 00000000
"One error found:"
Encoding: 0000246
Encoding: 0000007
Address 56: Radio
Encoding: 0004400
Encoding: 0000144
Address 69: Trailer
Encoding: 0000001
Encoding: 0000144
Encoding: 0010001
Encoding: 0000411
End--(Duration: 01:28, Battery voltage start/end: 11.9V/11.8V. Initial voltage: 11.9V)---
Translated on 24-09-2026, 13:26.
Uwe
Under conditions like the ones described above, there is mostly no access to the climate control or steering functions, and the system constantly disconnects or the control unit does not respond. During the car scan, the steering function always works, but the climate control never does, as indicated in the message below. I have no idea why icon_sad.gif.
The reason for the repair is error code 17911 and 1486. If anyone knows anything about it...
Thursday, May 2, 2019, 2:14:55:00397
Vehicle Identification Number: VSSZZZ6LZ4R011348
License plate: EMS SW 321
Mileage: 241,360 km. Repair order:
Vehicle type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Mileage: 241,360 km
Label file: DRV\038-906-019-ASZ.lbl
Part number: 038 906 019 DQ
Component: 1.9L R4 EDC G000SG 1536
Encoding: 00002
Operating number: WSC 06402
VCID: 698E4DB58069FA9F29B-4B3C
VSSZZZ6LZ4R011348 SEZ7Z0C2120105
3 error codes found:
17664 - Coolant temperature sensor (G62).
P1256 - 35-10 - Open circuit/short circuit after positive - Intermittent.
17911 - Generator terminal load signal.
P1503 - 35-10 - Implausible signal - Intermittent.
17964 - Charge pressure control.
P1556 - 35-00 - Limit exceeded.
Readiness: 0 0 X X X
Label file: DRV\6Q0-907-37x-ESP.lbl
Part number: 6Q0 907 379 M
Component: ESP 5.7 front, part number H03 0001.
Encoding: 0003353
Operating number: WSC 06403 000 00000
VCID: 47CAAB0DF3BDECEF1FF-50D0
"One error found:"
01486 - System function test enabled.
000 - -
Address 08: Climate Control/Heating. Label file: DRV\6L0-820-043.lbl
Part number: 6L0 820 043 B.
Component: CLIMAtronic PQ24 0201
VCID: 2516018529F11EFFCD3-50D0
or error codes are not supported by the control unit.
or communication errors occurred.
Label file: DRV\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Encoding: 00652
VCID: 3B22C7FDBA75B80F8B7-50D0
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 S
Part: 14 AIRBAG VW5 07 0007
Encoding: 12596
Operating number: WSC 06441
VCID: 47CAAB0DF6BDECEF1FF-50D0
Label file: DRV\6L0-920-xx0-17.lbl
Part number: 6L0 920 820 K
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V10
Encoding: 00145
VCID: 323CEAD96D3F7947581-50D0
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: 60 GATEWAY CAN 1S33
Encoding: 00014
VCID: 70B820D1A3B30B576E5-50D0
Label file: .DRV\6Q0-959-433.clb
Part number: 6Q0 959 433 E
Component: 02 Comfort Device, 0002.
Encoding: 00065
Operating number: WSC 42544
VCID: 3D26C9E5A461B63FB53-4B1E
Subsystem 1 - Part number: 6Q2959802C
Component: 02 TÔrsteuer.FS KLO 0003
Subsystem 2 - Part number: 6Q2959801C
Component: 02 Törsteuer.BF KLO 0003
End --(Duration: 02:41, Battery Voltage Start/End: 12.2V/12.2V. Voltage Drop: 0.0V)----
Translated on 24-09-2026, 14:06.
Karma: +1343 / -0   Thank you, like it!
Post04-05-2019, 7:36    Subject: Differential Pressure Sensor - No Access Quote
In the last vehicle scan, the summary of the control unit (ECU) status is missing at the beginning. That information is necessary.
What's noticeable:
- The braking system's electronics are stuck during a system test.
- The climate control system is not communicating - perhaps something is not configured correctly somewhere?
Translated on 24-09-2026, 14:17.
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential Pressure Sensor: Explained Diesel Engine Technology
No new posts T5 Differenzdrucksensor On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor Diesel Engine Technology
No new posts When is a differential pressure sensor dead? Diesel Engine Technology
