Auto-saved file disappeared after saving
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post23-04-2019, 11:19    Subject: Auto-saved file disappeared after saving Quote
Hello everyone,
Yesterday, I used Autoscan to read the diagnostic data from a Golf 4.
To save the file, I pressed "Save" instead of "Choose location."
A window popped up where I could enter the data (name, license plate, etc.). After that, I clicked "Confirm" and it was done.
A short time later, I tried to access the saved file, but it was gone.
Where did she go?
If you only click "Save," where will the file be saved?
Is it within the VCDS system itself, or on the computer?
If it's on a computer, then where?
I then ran Autoscan again to try and select the save location, but nothing happened. The "Save location" button is no longer there; only the "Save" button is visible.
Your help with this matter would be appreciated.
HG
Michi.
Translated on 27-08-2026, 10:05.
vag-driver
dieselschrauber likes this.
Post23-04-2019, 14:25    Subject: Auto-saved file disappeared after saving Quote
For example, in Windows 10, you can find it here:
C:\Ross-Tech\VCDS-DRV\Logs
Using the "Search by modification date" function in File Explorer should make the file findable.
Andreas
Translated on 27-08-2026, 10:06.
amishorty
Post23-04-2019, 22:22    Subject: Autoscan File Disappears After Saving Quote
Hi Andreas,
Your tip was very helpful.
Thank you again.
File moved back to the correct folder.
HG
Michi.
Translated on 27-08-2026, 10:07.
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW & Audi: Store Maintenance & Repair Data Diesel Engine Technology
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts MFA After Eco-Tuning On-Board Diagnostics (OBD)
