Audi A4 B7 Starter Motor 3.0 TDI
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
HennerVw
2004 Seat Leon
Post06-09-2019, 20:48    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
Hello everyone!
I bought an Audi A4 B7 3.0TDi with a Tiptronic transmission, engine code ASB. It had a timing chain failure on the second cylinder bank. After a lot of testing, I finally located the problem, and up until that point, the car wouldn't start because the timing chain had broken (the starter motor was working perfectly). Now, I've replaced everything, reassembled it all, and now the starter motor isn't working. Terminal 50 isn't receiving power. (The car starts and runs fine if I bypass the starter relay). So, my actual question is: Which relay is the starter relay in this Audi? Where is it located? And does anyone have an original wiring diagram for the starting system so I can make some measurements and troubleshoot the problem? Thank you very much for your help, and best regards from Rügen.
DieselElite
Translated on 07-09-2026, 19:37.
Karma: +1340 / -0   Thank you, like it!
Post06-09-2019, 21:48    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
How about https://erwin.audi.com/erwin/showHome.do?
You'll find what you're looking for for that model/vehicle there.
Translated on 07-09-2026, 19:38.
HennerVw
2004 Seat Leon
Post06-09-2019, 22:49    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
"Only the connector in the water tank is visible there, because the side panel doesn't really work for me, and it's supposed to be the J207 relay... but is that the correct relay number that's also printed on the cover?"
I'm viewing it on my phone.
DieselElite
Translated on 07-09-2026, 19:39.
Post07-09-2019, 6:15    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
What kind of document were you looking at?
HennerVw
2004 Seat Leon
Post07-09-2019, 7:41    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
Hi, wiring diagram number: 115/2.
DieselElite
Translated on 07-09-2026, 19:40.
Post07-09-2019, 9:20    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
Try searching for the term "starter". You should also be able to find the related parts (relay, fuses, etc.) and their installation locations.
HennerVw
2004 Seat Leon
Post07-09-2019, 9:25    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
The problem is that no matter where I click, I can't scroll down any further. It always only shows me the first page, even when I click on a different link. So, if anyone has a PDF file, I would be very grateful.
DieselElite
Translated on 07-09-2026, 19:41.
Post07-09-2019, 9:33    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
You need to download the PDF file to your computer. For the B7 model, it's likely to be several hundred pages, and within that, you'll find the information that applies to your specific model year and engine type. You can search through it using Adobe.
That won't work on a mobile phone.
HennerVw
2004 Seat Leon
Post07-09-2019, 9:37    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
Okay, I understand. I'm going to check the relay connected to the brown plug in the electrical box today to see if anything happens.
DieselElite
Translated on 07-09-2026, 19:42.
Post07-09-2019, 9:54    Subject: Audi A4 B7 Starter Motor 3.0 TDI Quote
You can do both with the flat rate: access content online and download it.
And if you already have a flat rate (even just one hour is enough), you can download all the documents that are relevant to you.
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Starter Motor Problem: Won't Crank/Stuck Electrical Systems, Vehicle Electronics, Multimedia
No new posts Anlasser SDI On-Board Diagnostics (OBD)
No new posts Starter Motor Touran BRU Diesel Engine Technology
No new posts Kompatibilität Tdi Anlasser Diesel Engine Technology
