Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking?
Karma: +807 / -0   Thank you, like it!
Post15-11-2016, 11:35    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
In one of my "premium" vehicles (an Audi A3 2.0 TDI), a service is due, and during the inspection, I noticed oil leaks on the cylinder head, as shown in the photos. The engine code is CFFB, with only 136,000 km. icon_sad.gif
Using a lighter, I tried to locate the source of the oil fumes, but unfortunately, I couldn't find anything. Therefore, I suspect that there might be a leak somewhere in the plastic seals of the cylinder head cover/oil separator.
Does anyone know if there's a known cause for this issue?
To remove the hood, you need to take out the injectors and disassemble the fuel rail. It's a lot of work, and there are many things that can go wrong. icon_evil.gif
It would have been better if I had gone with Skoda back then; the same technology for a reasonable price. icon_rolleyes.gif
Tips regarding cylinder head covers are welcome.
 File size:  1.62 MB
 Viewed:  5422 times
 File size:  1.54 MB
 Viewed:  3748 times
Translated on 20-07-2026, 13:10.
chli1976
dieselschrauber likes this.
Post15-11-2016, 12:52    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
"It usually leaks somewhere around the filler neck, and I think there's even a technical service bulletin (TPI) for it. They used to replace the caps, but now they just glue them on."
VCDS
Translated on 20-07-2026, 13:12.
Post15-11-2016, 13:15    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
chli1976 wrote:
It usually leaks somewhere near the filler neck, and I think there's even a Technical Service Bulletin (TPI) for it. In the past, they would replace the caps, but now they just glue them.
It would be great if that were the case... Does anyone happen to know about these TPIs? Or does anyone know where the leak is coming from?
sepp.bayern
Post03-12-2016, 14:35    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
Hello Rainer,
I have a Skoda, and on my car, the oil level indicator is in the same place as it is on yours.
And that's been the case since the very first inspection.
I have never taken any action against it, and I won't in the future either.
Best regards, Christian.
Skoda Octavia 1Z5 CFHC Mj2012 Aktuell ca. 140.000km
Translated on 20-07-2026, 13:13.
Post09-12-2016, 11:10    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
There's a cautious sign of relief. After I patched a small crack in the connecting pipe of the crankcase ventilation system, no more oil has leaked out.
The area where the friction is occurring is somewhat distant (fiberglass material on the turbocharger), and it didn't occur to me that it could be a possible cause of the oil leaking onto the injector.
The fact is that there is no more oil accumulating on the injector now.
Translated on 20-07-2026, 13:14.
Princ3
Post27-06-2020, 12:23    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
Hello Rainer,
Could you please describe in more detail where the area that was damaged or worn through was located?
My valve cover looks exactly like yours, and your solution sounds promising.
Thank you and best regards.
Bernd.
Translated on 20-07-2026, 13:15.
Post27-06-2020, 20:39    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
The fiberglass insulation (heat shield) from the turbocharger had rubbed against the black plastic corrugated tube (crankcase ventilation).
Translated on 20-07-2026, 13:16.
Karma: +649 / -0   Thank you, like it!
Post29-06-2020, 3:45    Subject: Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Quote
No advertising, just a note: https://www.autowelt-baumann.de/KFZ-Zubehoer/Oele/Kontrastmittel-Motoroelsystem::6113.html
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Leaky Heater Valve - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cylinder head cover leak AMF Diesel Engine Technology
No new posts Audi A4 AC Leak: Repair & Troubleshooting Transmission, Chassis, Body & Interior
No new posts Audi 8e/B6: Leaky Washer Fluid Reservoir. Transmission, Chassis, Body & Interior
No new posts Audi A4 Leak: AHH VP37 Repair Guide Diesel Engine Technology
