Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
abicim
Post30-11-2020, 19:13    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Hello everyone,
I have a Golf 5, manufactured in 2006, and for some time now, I've been hearing a noise when the car is stationary.
During the ride, everything seems normal and there are no unusual sounds. What could it be?
Thank you in advance.
Golf 5 2.0 TDI DSG: Engine or Transmission Noise? - Vw Golf 5 2.0 TDI DSG Ruckelt - YouTube.webm
 File size:  4.44 MB
 Viewed:  1468 times
Translated on 26-10-2026, 21:35.
alevuz
Karma: +32 / -0   Thank you, like it!
dieselschrauber likes this.
Post01-12-2020, 15:56    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Hello...
Suspected ZMS failure ---- You can't press the clutch pedal with a DSG transmission, so doing so might make it quieter...
He's shaking quite a bit.
It's difficult to verify that with a DSG, unfortunately...
SG.
Manfred.
Touareg V10 TDI (AYH)
abicim
Post02-12-2020, 20:56    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Is there an alternative to ZMS? Or can I be sure that the ZMS is defective?
Translated on 26-10-2026, 21:36.
Karma: +649 / -0   Thank you, like it!
Post06-12-2020, 10:19    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Alternatively, the transmission, but that needs to be removed anyway.
Be prepared to potentially spend around 2000 euros if a repair shop gets involved.
Karma: +807 / -0   Thank you, like it!
Post08-12-2020, 21:03    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
I'd like to check if the noise is still present when there's some torque applied to the drivetrain.
When starting uphill, use minimal gas. If the noise doesn't decrease, I wouldn't rule out other causes besides the dual-mass flywheel (DMF), such as tensioners and idler pulleys in the belt drive.
Just remove the engine cover; it's just clipped on.
Wie ist denn der Kilometerstand? Untuned engine?
Translated on 26-10-2026, 21:37.
abicim
Post08-12-2020, 21:19    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
The noise is only present when the engine is idling, not when there is torque being applied.
Mileage: 162,000 km
Engine: Untuned.
Timing belt: replaced at 139,000 km.
Best regards, Orhan.
Translated on 26-10-2026, 21:38.
Post08-12-2020, 21:22    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
abicim wrote:
The noise is not present when there is torque, but only when idling.
Mileage: 162,000 km
Engine: Untuned.
Best regards, Orhan
Okay, then I'll focus on the powertrain.
Translated on 26-10-2026, 21:39.
abicim
Post08-12-2020, 21:23    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Okay, so ZMS?
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post10-12-2020, 9:21    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Hi!
Based on the metallic "clanging" sound combined with the engine wobble, I also suspect a worn-out dual-mass flywheel (DMF).
Reason: I experienced the same issue with my 1.9 PD TDI. I ignored it (because it had 260,000 km on it) and ended up paying a high price. I broke down on the highway due to engine failure. The imbalance in the dual-mass flywheel (DMF) was so severe that the crankshaft broke after the second cylinder.
Used engine from a recycling center plus installation: 3500,- icon_cry.gif
Beste Grüße,
Hufe
Translated on 26-10-2026, 21:40.
abicim
Post10-12-2020, 12:39    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
Do I need to pay special attention to the dual-mass flywheel (DMF) when replacing it in a DSG automatic transmission, or is it similar to replacing it in a manual transmission?
Translated on 26-10-2026, 21:41.
abicim likes this.
Post10-12-2020, 19:38    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
abicim wrote:
Do I need to pay special attention to the dual-mass flywheel (DMF) when replacing it in a DSG automatic transmission, or is it similar to a manual transmission?
If you want to do it yourself, I recommend getting the relevant repair manuals from Erwin.
Without a stage or pit in a heated workshop, it's unlikely to work out.
Translated on 26-10-2026, 21:42.
Post12-12-2020, 17:03    Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise? Quote
"Heating is overrated; it only works for me in the summer."
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Manual transmission, Difficult to shift gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Sounds: Clicking/Popping Noises (Until 09/2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. VW Touareg: Clicking 3.0 V6 Kong Engine Noise? Diesel Engine Technology
No new posts Engine Clicking? Get Help Now! Diesel Engine Technology
No new posts Golf 2 5-speed gearbox: 1.3L, 40kW engine? Diesel Engine Technology
No new posts Passat 3C: Transmission or Dual Mass Flywheel? Diesel Engine Technology
