P1640 Error After Update: Troubleshooting Guide
Satmaster
Post05-12-2021, 8:37    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Hello community.
I had my engine control unit (ECU) updated by a tuner, and now I'm getting this P1640 error code every time.
What could be the cause of this?
Is there anything I need to consider during installation, or do I need to use VCDS to program it?
Okay, here's the translation:
"Vg AR"
Translated on 11-10-2026, 13:16.
Post05-12-2021, 8:55    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Autoscan?
Translated on 11-10-2026, 13:17.
Satmaster
Post05-12-2021, 9:24    Subject: P1640 Error After Update: Troubleshooting Guide Quote
I will send you the Autoscan results tomorrow. I only have a Screenshot of the error at the moment.
 Fehler p1640
 File size:  670.41 KB
 Viewed:  1487 times
Post05-12-2021, 9:28    Subject: P1640 Error After Update: Troubleshooting Guide Quote
You had your engine control unit (ECU) tuned, and now it's saying it's defective.
Do you remember anything?
Satmaster
Post05-12-2021, 9:30    Subject: P1640 Error After Update: Troubleshooting Guide Quote
No tuning, just a software update from version 0030 to 0050.
Karma: +1353 / -0   Thank you, like it!
dieselschrauber likes this.
Post05-12-2021, 10:28    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Why don't you go back to the "tuner" who installed the software? His diagnosis seems wrong ("ECU defective, EEPROM error"). That's a pretty fundamental issue within the ECU. VW or Audi certainly wouldn't have caused that.
Translated on 11-10-2026, 13:18.
Satmaster
Post05-12-2021, 12:10    Subject: P1640 Error After Update: Troubleshooting Guide Quote
I naturally went to the tuner, and he said he didn't know what to do either, which certainly doesn't speak well for the quality.
Sure, I won't recommend that tuner to anyone else.
I was hoping to get some tips based on your experience so I could figure out how to proceed.
Translated on 11-10-2026, 13:19.
Herbert likes this.
Post05-12-2021, 14:35    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Satmaster wrote:
I naturally went to the tuner, and he said he didn't know what was wrong either, which obviously doesn't speak well for the quality.
I thought I would get some tips based on your experience so I could see how to proceed from here.
Play the original file. It's a shame if the EEPROM error persists because no meaningful changes were made during the flashing process. However, there are also knowledgeable tuners who can fix this. icon_idea.gif
I'm wondering why someone would have their engine control unit (ECU) updated after 300,000 km, whether it's with or without tuning.
What extremely urgent problem has existed for 300,000 km that would require paying for an update?
Translated on 11-10-2026, 13:20.
Satmaster
Post06-12-2021, 8:52    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Why did I install the update?
The engine warning light came on in the display.
Get the error codes read.
- The signal was too rich, which affected the lambda sensor. I ordered a new lambda sensor, replaced it, and the error disappeared.
- P242F: Maximum load exceeded, unfortunately, the issue persisted.
Trying to start a manual regeneration using encoding II and the code 10016.
Unfortunately, the regeneration process always stops prematurely, and the new values are not saved.
The issue where the values were not being saved is known to occur with software version 0030, but has been resolved in version 0050 and later.
"The person I spoke with was very friendly, but they wanted to charge me a few hundred euros just to do a diagnostic test to see if an update was possible."
After that, I contacted a few tuners and asked if they could perform an update.
That's why I wanted to do the update.
If you can recommend a reputable tuner who can fix my engine control unit (ECU), I would be very grateful for a private message.
VG AR
Translated on 11-10-2026, 13:22.
Post06-12-2021, 13:42    Subject: P1640 Error After Update: Troubleshooting Guide Quote
Stupid question... Maximum load exceeded... 310,000 km... Maybe I just assumed the filter might be full...
Translated on 11-10-2026, 13:24.
Satmaster
Post06-12-2021, 14:18    Subject: P1640 Error After Update: Troubleshooting Guide Quote
The DPF (Diesel Particulate Filter) was replaced last year, according to the invoice from the previous owner, and currently has an oil ash content of 0.04 [?].
Satmaster
Post07-12-2021, 22:05    Subject: Automatic Scanning: Fast & Easy Solution Quote
I've now run a car scan for my friend and attached the results.
Log-WAUZZZ4F0xxxxxxxx-310960km.txt
 Autoscan
Autoscan
 File name:  Log-WAUZZZ4F0xxxxxxxx-310960km.txt
 File size:  22.96 KB
 Downloaded:  306 times
chli1976
Post08-12-2021, 10:47    Subject: P1640 Error After Update: Troubleshooting Guide Quote
As far as I know, the problem you're referring to has already been fixed in the 0030 model. It affected the 0010 model, and it wasn't possible to initiate the regeneration process on that model.
What year is it?
Find someone with a VCP (Vehicle Control Panel) and try flashing an SGO or FRF (firmware).
If the error still persists after that and it's still an EDC16, then it can be repaired using a BDM file. However, if it's already an EDC17, it becomes a bit more complicated.
So, you initially had a problem with the DPF, not the software, but now you have both.
VCDS
Translated on 11-10-2026, 13:25.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unable to save after update On-Board Diagnostics (OBD)
No new posts No Connection to Control Unit After Update On-Board Diagnostics (OBD)
No new posts GRA Supplemental Restraint System (SRS) Installation Erro... On-Board Diagnostics (OBD)
No new posts MSW 1Z: Many errors after cleaning On-Board Diagnostics (OBD)
