Pegasus
10-09-2022, 13:11 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Hello everyone,
Unfortunately, I couldn't find an answer using the search function.
I recently bought an A4 B8 quattro with an S-tronic transmission and a 2.0 CGLC engine.
150,000 km, car is in excellent condition, new inspection (TÜV) and emissions test (AU), only the fuel consumption is a drawback, according to the onboard computer it averages 8.0 liters.
At the gas station, I drove 500 km with 50 liters of fuel, which is 10.0 liters per 100 km, driving economically! I always drive 15-20 km on country roads at a time.
Error memory is clear, injector values are okay, MSG is original.
What could be the cause of the high consumption?
Thank you and best regards.
Translated on 18-09-2026, 16:00.
Joined: 04/12/2002 Posts: 18114 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
10-09-2022, 16:51 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
The intercooler has a leak; you should be able to hear it, even without having Pattex in your ears.
Wheels that are difficult to turn or brakes that squeal often reveal themselves through excessively high temperatures.
A full DPF and resetting the mileage would also be an option. The amount of ash/ash volume in the DPF can be checked using VCDS.
Translated on 18-09-2026, 16:02.
Profile PM WWW Garage |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber likes this. |
10-09-2022, 19:41 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Quattro (all-wheel drive), automatic transmission, high weight, wide tires... overall, these are normal features.
Translated on 18-09-2026, 16:03.
Profile PM Garage |
Pegasus
10-09-2022, 20:20 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
I'll check the DPF values tomorrow. No matter how short or long the drive, the fan runs afterwards.
I can't imagine consuming more than 3 liters above the manufacturer's stated fuel consumption.
10-09-2022, 20:46 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Rüdi wrote: | | Quattro, automatic transmission, high weight, wide tires... all things considered, it's normal | .
Yes, I don't know, but I used to get 10 liters per 100 kilometers with my Audi A3 and a trailer.
I'm currently getting about 7.5 liters per 100 kilometers with my T6.
Perhaps the person asking the question is driving digitally and revving each gear up to 4000 rpm. X
Translated on 18-09-2026, 16:04.
Herbert Profi-Schrauber
10-09-2022, 21:10 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
These things are fuel guzzlers if driven carelessly. Especially at temperatures below 20°C and on "short" trips, they also don't warm up properly. I know this from my experience with my A4, although not to the same extent.
Observe the displayed instantaneous power consumption in relation to your gas pedal.
Translated on 18-09-2026, 16:05.
Pegasus
10-09-2022, 21:42 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
I don't think I drive recklessly; I rarely use full throttle.
None of my previous diesel cars, ranging from 1.9 to 3.0 liters, have consumed 10 liters per 100 kilometers with my driving style!
Translated on 18-09-2026, 16:06.
Ich_Can_nix Profi-Schrauber
10-09-2022, 23:57 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Hello Pegasus,
Pegasus wrote: |
I cannot imagine consuming more than 3 liters above the factory specification. |
The technical specification likely dates back to a time before Audi implemented the "23Q7" field measure for the EA189 engine as part of a confidence-building measure.
If you refer to the software as "original" after the Dieselgate scandal, you will have a hard time achieving the stated fuel consumption figures.
Can you rule out a leak? Some engines are prone to strong vibrations after the update, which can cause pipes/clamps to come loose.
Michael.
Translated on 18-09-2026, 16:07.
11-09-2022, 7:46 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Hi there.
Let's go through the procedure again.
- Autoscan,
- Values of the particulate filter (ash, soot, differential pressure, threshold values, mileage, etc.).
- Differential pressure measurement as shown here: https://community.dieselschrauber.org/en/viewtopic.php?t=24222
Translated on 18-09-2026, 16:08.
Pegasus
11-09-2022, 9:40 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Good morning.
Since I don't have VCDS myself, I had to bother a friend, early Sunday morning, which is the best time, but I was really curious! He only had a short amount of time, but I think that was enough!
If you know where to look, you can find what you're looking for.
Based on how I'm interpreting the values, it seems my DPF is overloaded and that's why it's regenerating roughly every 50 kilometers.
Or am I seeing something wrong?
MKB: CGLC
MSG: 03L 906 018 KM
373 Particle filter differential pressure (engine idling) 10 hPa
372 Particle filter differential pressure: -11 hPa.
133 DPF Statistics, Distance traveled since successful regeneration: 65686 m.
059 Loading limit for field regeneration: 22.53 g.
060 Service refill limit: 40.00 g.
061 Loading limit - Overload: 50.00 g
377 kilometers since the last regeneration of the particulate filter.
12116 meters.
380 Particle filter Oil ash content: 52.9 g
381 Particle filter Oil ash volume: 0.31 l
382 Particle filters, calculated soot mass: 1432 g.
383 Particle filter, soot mass measured: 23.99.
384 Particle filter. Time since last regeneration: 902 seconds.
Translated on 18-09-2026, 16:11.
11-09-2022, 15:21 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Quote: | | 381 Particle filter Oil ash volume 0.31 l |
Definitely. The limit value is 0.175 liters.
The question is, where does this come from, given the mileage of 150,000 km?
For comparison: I'm currently seeing 0.11 liters per kilometer with over 160,000 kilometers on the odometer (Audi A4 8K CJCD, of course, also with the software update, at around 50,000 kilometers).
The DPF needs to be replaced, but the cause of the abnormal loading should be identified.
Translated on 18-09-2026, 16:14.
Pegasus
19-09-2022, 19:54 Subject: 2.0 TDI: High Fuel Consumption - CGLC Engine |
Okay, the DPF was cleaned, but the replacement part from ERNST didn't fit.
I'm now curious to see how much energy it consumes...
"The software update was performed at 53,000 km. I suspect it might have been driven with a power box installed, which could explain the high ash content."
| Description: |
| File size: |
1.61 MB |
| Viewed: |
522 times |
Translated on 18-09-2026, 16:15.
