Garage4451
Joined: 09/15/2021 Posts: 8 Karma: +6 / -0 Location: Wintersingen
24-01-2023, 23:05 Subject: Assign label file to Audi S3 A B T |
Hello everyone,
Today, I tried to read the measurement data from the engine control unit (ECU) of an S3 8P manufactured in 2008, but I found that there was no label file available. I then searched on Google and discovered that this might be due to the A B T control unit, which has "A B T" in its part number. I also read something about a redirect file.
"Could someone possibly explain how to find and open the actual label file for the engine (CDLA 2.0)? Or even how to use the redirect file method?"
If I had a list showing which block contains each value, that would be enough for now. The vehicle is experiencing misfires on cylinder 3.
VIN: WAUZZZ8P99A076808
Best regards from Switzerland.
Translated on 18-07-2026, 16:34.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
24-01-2023, 23:49 Subject: Assign label file to Audi S3 A B T |
Yes, unfortunately, the engine control unit then provides a modified VAG part number.
Please post an Autoscan result. I would like to try copying the correct label file and then modifying it with the part number from the Autoscan.
It's possible that this could conflict with the redirection.
Translated on 18-07-2026, 16:36.
Profile PM WWW Garage |
Garage4451
26-01-2023, 18:29 Subject: Assign label file to Audi S3 A B T |
Unfortunately, I don't have a scan available right now; the vehicle will be brought in for diagnosis next week.
According to AKTE, the part number is: 8P0 907 115 AP.
I couldn't find that label file under the "LABELS" directory.
What could be the reason for that?
Best regards, Mischa.
Translated on 18-07-2026, 16:37.
26-01-2023, 18:46 Subject: Assign label file to Audi S3 A B T |
"Wildcards" are used in the label search.
Ross-Tech wrote: | Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part Number (Software): 8P0 907 115 AP Hardware: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010 |
The label file is 06F-907-115-CDL.clb  .
Translated on 18-07-2026, 16:38.
Garage4451
26-01-2023, 19:10 Subject: Assign label file to Audi S3 A B T |
Thank you very much, Rainer.
Can I view this as plain text somehow, or simply rename the file to the "A B T number"?
Translated on 18-07-2026, 16:39.
26-01-2023, 19:17 Subject: Assign label file to Audi S3 A B T |
The .clb file is encrypted. Use VCDS to access the engine control unit and rename the copied file to match the part number shown by A B T. Replace spaces with hyphens. Make sure to keep the .clb extension.
Translated on 18-07-2026, 16:40.
Garage4451
dieselschrauber and E30_V8 likes this. |
03-02-2023, 18:08 Subject: Problem solved |
I just wanted to let you know that the solution with copying and renaming worked perfectly.
Mischa.
Translated on 18-07-2026, 16:41.
E30_V8 Profi-Schrauber
Joined: 06/15/2022 Posts: 94 Karma: +111 / -0 Location: ...aus dem Herzen der Natur! 2005 Skoda Fabia  Premium Support
03-02-2023, 18:40 Subject: Assign label file to Audi S3 A B T |
Thank you for the feedback!
Polo V 1,6 Tdi (CAY)
Profile PM Garage |
