Golf V 1.4 Gasoline GRA retrofit failed
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
flugdiesel
Post06-07-2023, 19:28    Subject: Golf V 1.4 Gasoline GRA retrofit failed Quote
I installed a GRA (Gear Recommendation Assist) on my daughter's Golf V 1.4, manufactured in 2006. When enabling the function in control unit 16, I entered "2" as the second-to-last digit, as indicated in VCDS (GRA on the steering column without MFA). This was unsuccessful, and I always received the message "invalid value range"! Attempts with values 1, 3, and 4 also failed - the same error message appeared!
The engine control unit has accepted the registration, but that's not enough.
What can I do, or is it like the situation with car keys, where VW forces customers to go to a VW workshop, and that unlocking certain functions can only be done online with a connection from the VW dealer to the car?
PS: When trying to install the wire that connects to the water tank, which is necessary for older models, it turned out that the blue connector on the water tank is no longer present, so that can't be the problem!
Post06-07-2023, 20:25    Subject: Golf V 1.4 Gasoline GRA retrofit failed Quote
Please post the following files: Autoscan, CodingLog.CSV, and AdpLog.CSV.
With the given information, it's difficult to do much.
flugdiesel
Post07-07-2023, 18:38    Subject: Golf V 1.4 Gasoline GRA retrofit failed Quote
Here's the car scan. I don't know where to find the two CSV files.
Could it be that I also need a different control unit for the GRA retrofit?
Post07-07-2023, 18:55    Subject: Golf V 1.4 Gasoline GRA retrofit failed Quote
The other two files are located in the "Debug" folder of the VCDS installation directory.
The steering column control unit must be compatible with GRA, and not all of them are.
flugdiesel
Post08-07-2023, 8:30    Subject: here are the CSV files Quote
Thank you for the tip, here are the files.
CodingLog.CSV
 File name:  CodingLog.CSV
 File size:  1.57 KB
 Downloaded:  270 times
AdpLog.CSV
 File name:  AdpLog.CSV
 File size:  471 Bytes
 Downloaded:  252 times
E30_V8 likes this.
Post08-07-2023, 10:22    Subject: Golf V 1.4 Gasoline GRA retrofit failed Quote
You have changed the short coding of the steering column control unit (1K0 953 549 BB) from 2 to 21/32/22.
"There are two things wrong with this. First, the way the encoding works, like a bitmask where adding 10, 20, or 30 to the original value (2) to activate a single function, is unlikely. " See the popup that appears in VCDS when the mouse cursor is held over the coding input field.
See:
Page 23, Encoding/Coding.
Or also:
/viewtopic.php?t=27025&highlight=encoding
Secondly, the steering column control unit 1K0 953 549
BBhttps://shop.dieselschrauber.org/en/download/VCDS-Handbuch.pdf is most likely incorrect, as it does not support the cruise control function at all.
Without any guarantee, index funds BF or BN might work.
flugdiesel
Post09-07-2023, 7:28    Subject: Thank you Quote
Thanks for the tips, I'll start looking for a suitable control unit!
Christian.
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4, year 2003 - KOBD2Check - Operation failed On-Board Diagnostics (OBD)
No new posts Golf IV ARL: No Start After DPF Delete? Diesel Engine Technology
No new posts Label File Redirection Failed On-Board Diagnostics (OBD)
No new posts Gasoline in TDI Diesel Engine Technology
