cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
dieselschrauber likes this. |
08-12-2023, 14:42 Subject: High beam permanently activated, VW Caddy |
I have a VW Caddy III here that belongs to my cousin.
The ignition switch unit was defective, which meant the ignition could no longer be turned on.
Therefore, I was allowed to disassemble the entire unit and use a Dremel tool to take it apart in order to remove the cylinder.
The repair was successful; the car's steering lock is now released, and the ignition and starting functions are working again.
Unfortunately, since then, the high beam has been permanently activated. According to the wiring diagram, 6 wires run from the high beam switch to the slip ring, where they are adapted to the CAN bus in the control unit.
If I disconnect the cable from the switch to the slip ring, the high beam headlights turn off. In VCDS, I see the status as "horn" (meaning the lever is pulled) and, after disconnecting the cable, it shows "not activated." Mistakes are not discarded.
At the same time, I can test all the other functions on the levers, and they are working. (After disconnecting the plug, the turn signals also don't work, but they also run through the same 6 wires).
Subsequently, I replaced both the lever and the slip ring as a precaution, as measurements alone are not always sufficient to diagnose the problem. The error persists.
I'm slowly running out of ideas. Hopefully, someone else has a tip here.
Thank you very much!
Car data:
VW Caddy III
Year of manufacture: 2011
Year of first registration: 2012
Engine code: CFHC (2.0 TDI)
Mileage: 280,000 km
Ich_Can_nix Profi-Schrauber
08-12-2023, 22:30 Subject: High beam permanently activated, VW Caddy |
Good evening.
Have you ever performed an actuator test and controlled the high beam directly from the BNS (Bordnetzsystem)? Disconnect the connector - if the high beam is off, access it via the actuator test.
This allows us to rule out the BNS as a source of error.
Are the part numbers for the steering column switches and slip ring correct?
Is the LDS okay?
Based on your description, I assume you have an H7 lighting system.
Could you please set up an Autoscan?
Michael.
cksIT Blaumann
09-12-2023, 10:49 Subject: High beam permanently activated, VW Caddy |
Thank you very much for the helpful suggestions.
-High beam function works via actuator diagnosis even when the connector is disconnected.
- It is an H7 lighting system.
- LDS = Light switch? Yes, all levels are working.
- Part numbers: The steering column switch has the same part number. The slip ring has a "c" instead of a "b" at the back (5k0 953 549 b), which, according to some websites, should be compatible (and the error doesn't change at all when you replace it).
- Regarding the error memory: When the connector is disconnected, it naturally detects the error and stores it.
Quote: |
Saturday, December 9, 2023, 10:17:22:24354
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 21.9.0.6 HEX-V2 CB: 0.4555.4
Data as of: 20211022 DS330.0
shop.dieselschrauber.org
Vehicle Identification Number: WV2ZZZ2KZCX006459 License Plate:
Vehicle type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 37 42 44 46 52 56 69
Mileage: 279,700 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch wheel electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: Error 0010.
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
56-Radio -- Status: OK 0000
69 followers -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CFHC) Label file: . DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 NF, HW: 03L 907 309 R.
Part: R4 2.0l TDI H23 9978
Revision: 42H23--- Serial number: 00000000000000 CVN: 5BBA1501
Encoding: 0019001A042400080000
Operating Number: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018NF 003004
ROD: EV_ECM20TDI01103L906018NF.rod
VCID: 7BA2011A936092F3F27-802E
VINID: 9E60AAAAA09BA93A00006105244B006187
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104) Label file: . DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Encoding: 623C600D09220300460F06E99022C042300000
Operating number: WSC 35110 377 00155
VCID: 79AE1B1299DCA0E3E0B-802C
Address 08: Climate Control/Heater (J255) Label file:| DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 EB, HW: 5K0 907 044 EB.
Component: Climatronic H17 1010
Revision: 00003001
Encoding: 0000000002
Operating number: WSC 35110 790 50316
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 6FBA254AD718FE534EF-803A
Address 09: Central Electronics (J519)
Label file: . DRV\1K0-937-08x-09.clb
Part number SW: 2K5 937 086 B Hardware: 2K5 937 086 B
Component: BCM PQ35 M+ 011 1044
Revision: BD011001
Encoding: 411A0A3A80251A6B088800829400816403517288526F8160648000000040
VCID: 3536D722F5448483443-8060
Subsystem 1 - Part number: 1T1 955 119 A. Label file: DRV\1KX-955-119.CLB.
Part: Wiper 19051 26 0512
Encoding: 009795
Subsystem 2 - Part number: 1K0 955 559 AH. Label file: DRV\1K0-955-559-AG.CLB
Part number: RLS 240511 05 54 0403.
Encoding: 0230ED
Address 10: Parking Assist 2 (J446) Label file: . DRV\1K0-919-475.clb
Part number SW: 1K0 919 475 L, Hardware number: 1K0 919 475 L.
Component: PARKING ASSIST 006 1806
Revision: 00006000 Serial number: 0 263 004 450
Encoding: 110001
Operating number: WSC 50968 001 1048576
VCID: 3B22C11AD36052F3B27-806E
Address 15: Airbag (J234) Label file:| DRV\5K0-959-655.clb
Part number SW: 2H0 959 655 B, Hardware number: 2H0 959 655 B.
Part number: VW10Airbag013 H06 0013
Revision: -------- Serial Number: 003HN003NN39
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3332E93AFBB09AB36A7-8066
Crash sensor for driver-side side airbag:
Serial number: 3495RRB405T0I3H08PG$
Crash sensor for side airbag, passenger side:
Serial number: 3505RRB405F0I70IF0UI
Address 16: Steering Wheel Electronics (J527) Label file:| DRV\5K0-953-569.clb
Part number SW: 5K0 953 507 BA, HW: 5K0 953 549 C.
Component: Steering module 007 0080.
Revision: -------- Serial Number: 90422JKQ000HF
Encoding: 5080140000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_SMLSNGKUDS A05001
FILE: EV_SMLSNGKUDS_A05.rod
VCID: 70B82636CA26E1AB575-8024
4 error codes found:
226827 - Blinker switch.
B1144 13 [009] - Interruption.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1
Lost Count: 156
Mileage: 279705 km
Date: 2023.12.09
Time: 00:03:51
226859 - Blinker switch.
Error priority: 2
Error frequency: 1
Lost Count: 156
Mileage: 279705 km
Date: 2023.12.09
Time: 00:03:51
226875 - Flasher switch.
Error priority: 2
Error frequency: 1
Lost Count: 156
Mileage: 279705 km
Date: 2023.12.09
Time: 00:03:51
227387 - Wiper switch.
B1145 13 [009] - Interruption.
Error priority: 3.
Error frequency: 1
Lost Count: 156
Mileage: 279705 km
Date: 2023.12.09
Time: 00:03:51
Address 17: Terminal block insert (J285) Label file: DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 2K0 920 875 E, Hardware number: 2K0 920 875 E.
Component: COMBINATION UNIT H03 0607
Encoding: 181A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 313EE33201ACA8A318B-8064
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 A
Component: Standing heater 043 4730
Revision: 00043000 Serial number: 09022127000000
Encoding: 0031012
Operating number: WSC 35110 377 00170
VCID: 3332E93AF7309AB36A7-8066
Address 19: Diagnostic interface (J533)
Label file: . DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 H, HW: 1K0 907 951.
Component: J533 Gateway H42 1620.
Revision: H42 Serial Number: 290511F2001273
Encoding: 357400
Address 25: Immobilizer (J334) Label file:| DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8C345EECFA1B7B191-803E
Address 37: Navigation (J794) Label file:| DRV\1K0-035-27x-37.clb
Part number SW: 3C0 035 279 C HW: 3C0 035 279 C
Part number: RNS315-EU H32 0263
Serial number: VWZAZ2L3358351
Encoding: 000004110200130000029001
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2312197A4B500A339A7-8076
Data storage devices:
Subsystem 1 - Part number: 3AA 919 866.
Component: EUR_W_V11 0073
Address 42: Door electric driver. Label file: . DRV\1K0-959-701-MIN3.clb
Part number SW: 1T0 959 701 T Hardware number: 1T0 959 701 T
Component: Door Seal 009 2109
Encoding: 0000048
VCID: 48C8AED69EB6096B2F5-801C
Address 44: Steering Assist
Label file: DRV\1K0-909-14x-GEN3.clb
Part number: 1K0 909 144 M
Component: EPS_ZFLS, Size 140, Part Number 3201.
Revision: 00H20000
VCID: 3430EA26F23E9D8B73D-8060
"1 error found:"
03803 - Steering angle sensor for power steering.
000 - - - Warning light ON.
Error status: 11100000
Error priority: 2
Error frequency: 1
Lost Counter: 255
Mileage: 279705 km
Time: 0
Date: 2018.05.01
Time: 00:03:51
Battery voltage: 12.3 V
DD
Temperature: 12.0°C
Quantity: 2
Steering angle: 0.00°
Quantity: 0
Lenkwi k.lnit
Address 52: Door electronics, passenger side. Label file: . DRV\1K0-959-702-MIN3.clb
Part number SW: 1T0 959 702 R, HW: 1T0 959 702 R.
Encoding: 0000048
VCID: 47CAADEA93A8061326F-8012
Address 69: Trailer (J345) Label file: . DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 H, HW: 1K0 907 383 G.
Part: Trailer H12 0130
Revision: 3B001001 Serial number: 00000375477619
Encoding: 0100000101000000
Operating number: WSC 50163 001 1048576
VCID: 323CEC3E042A93BB611-8066
End -------- (Duration: 01:02, Battery voltage start/end: 12.1V/12.2V) --------
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
09-12-2023, 11:46 Subject: High beam permanently activated, VW Caddy |
Error priority: 2
Error frequency: 1.
Lost Count: 156
Mileage: 279,705 km
Date: 2023.12.09
Time: 00:03:51
226859 - Flashing light switch.
Error priority: 2
Error frequency: 1.
Lost Count: 156
Mileage: 279,705 km
Date: 2023.12.09
Time: 00:03:51
Error priority: 2
Error frequency: 1.
Lost Count: 156
Mileage: 279,705 km
Date: 2023.12.09
Time: 00:03:51
Error priority: 3.
Error frequency: 1.
Lost Count: 156
Mileage: 279,705 km
Date: 2023.12.09
Time: 00:03:51
Is it possible that the wiring harness near the steering column is damaged in a place that isn't immediately visible?
I once had similar problems with the windshield wipers on my A3 8L. There was metal debris on the steering column switch.
If it were my car, I would use brake cleaner (be careful of plastic discoloration, test it first) and have rags ready to wipe it off, or ideally, with the car battery disconnected.  Metal debris can sometimes cause sparks.
Or, let's start with compressed air.
Profile PM WWW Garage |
cksIT Blaumann
dieselschrauber, Hutfahrer, Turbinchen and E30_V8 likes this. |
10-12-2023, 10:15 Subject: High beam permanently activated, VW Caddy |
Thank you for the tip!
I hadn't thought of that yet.
The problem has now been resolved. But you really couldn't make this stuff up.
The new used steering column switch was defective (with the same effect as the old one, namely constant high beam activation in the VCDS) and the new used slip ring is also defective. This cannot be encoded.
In conjunction with the new slip ring and the new steering column lever, an error message "Mechanical fault in the turn signal lever" was logged after a timeout (this time I had tested for a longer period), and the horn was deactivated.
After that, I went through all the possible scenarios again. The old lever arm doesn't store any mechanical errors, but neither does the new lever arm with the old slip ring.
After that, I opened the old lever and saw that the slider on the circuit board for the high beam wasn't properly seated. After the correction, it is now working as it should. --> On the old slip ring.
I rarely receive defective used parts, but getting two at once is quite a challenge...
Thank you again for your support!
10-12-2023, 10:18 Subject: High beam permanently activated, VW Caddy |
Thank you for the feedback  .
