Recode Audi A6 4G GRA to 1 km/h
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
fuhrer24
Post06-11-2024, 14:19    Subject: Recode Audi A6 4G GRA to 1 km/h Quote
Hello everyone,
Is it possible to recode the speed step size from 10 km/h to 1 km/h on the Audi A6 4G (2019) for the adaptive cruise control (ACC) system?
Max
MARKAU A6.txt
 Auszug VCDS Distanzregelung Steuergerät
 File name:  MARKAU A6.txt
 File size:  1.87 KB
 Downloaded:  235 times
Karma: +436 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-11-2024, 9:30    Subject: Recode Audi A6 4G GRA to 1 km/h Quote
It's possible that I'm about to embarrass myself multiple times, as I haven't driven the new model year yet.
According to Wikipedia, 4G technology was only deployed from 2012 to 2018. Therefore, the year your device was manufactured is likely 2018 or earlier, not 2019. You might want to check the model year using the VIN (Vehicle Identification Number).
2) If I'm not mistaken, the car should still have the controls located on the lever below the turn signal (and not on the steering wheel).
For all my vehicles from the VAG group, it was already possible to adjust the speedometer by +/- 1 km/h from the factory.
Up/down = +/- 10 km/h or +/- 5 miles per hour.
Res/Set = +/- 1 km/h or 1 mph.
You need to pull the lever for icon_smile_thumb_up.gif km/h and press the button for -1 km/h.
Have you already tried it like this?
Guste.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Codierung des APS bei Audi Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Recode engine control unit On-Board Diagnostics (OBD)
No new posts Steuergerät umcodieren On-Board Diagnostics (OBD)
No new posts A8 bj. 2005 aus USA ruckleuchten umcodieren On-Board Diagnostics (OBD)
No new posts TDI Motorsteuergerät umcodieren (Warmstartproblem) On-Board Diagnostics (OBD)
