No access permission to diagnostic interface 019 on Golf 8
Buddy11
Post06-01-2025, 15:54    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
I would like to replace the battery in my Golf 8, manufactured in March 2020.
Adjust the diagnostic interface in control unit 019.
The Vcds software is currently version 24.7.1, and I also have the required dongle for it.
Unfortunately, I'm not seeing any numbers for the access permissions, but I need those in order to adjust the new values.
Who has a solution for me?
Best regards, Udo.
Translated on 07-07-2026, 11:43.
Post06-01-2025, 20:14    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Autoscan?
Translated on 07-07-2026, 11:46.
Buddy11
Post07-01-2025, 19:24    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Hello Rainer,
An Autoscan was performed, but no authorization codes are still being displayed.
Please attach the log file.
Best regards, Udo.
Log-WVWZZZCDZLW002072-55427km-nicole3.txt
 File name:  Log-WVWZZZCDZLW002072-55427km-nicole3.txt
 File size:  17.6 KB
 Downloaded:  1147 times
 File size:  17.6 KB
 Downloaded:  913 times
Translated on 07-07-2026, 11:47.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-01-2025, 20:44    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Good evening, Buddy11.
Your vehicle is equipped with SFD.
Did you have the parking brake engaged and the hood open while adjusting it?
Michael.
Translated on 07-07-2026, 11:51.
Buddy11
Post08-01-2025, 11:25    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Hello Michael,
Yes, I had already done everything, and the SFD status indicates that.
SFD individualization feature set.
When I try to unlock the control unit,
Then it says "token error."
I can do whatever I want, but I'm not getting any numbers displayed when I try to access the authorization settings. And without those numbers, I obviously can't pair the new battery.
Perhaps there's another solution.
Best regards, Udo.
Translated on 01-10-2026, 16:22.
Ich_Can_nix
dieselschrauber and Herbert likes this.
Post08-01-2025, 12:54    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Hello Buddy11,
Then you have three options.
- You register for the Volkswagen after-sales program and obtain access. Then, you can generate a token via the app.
However, starting in 2025, you will also need a Serma certificate.
- You search online for a suitable provider. There are some people who can use TeamViewer to do the coding for you.
- You have it coded at the workshop.
- or you could ask if anyone in your area is active in this forum and might be able to help.
You can't proceed without a token!!
Michael.
Translated on 07-07-2026, 12:01.
Buddy11
Herbert likes this.
Post08-01-2025, 17:08    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Hello Michael,
First of all, thank you for saving me the trouble of doing further research.
I just visited a former colleague (who used to work at Audi/VW) who now runs his own workshop. He complained to me about the things he has to do for these cases, especially regarding the special "Serma" certification. It's even more complicated with other manufacturers like Mercedes. Well, I really don't know if I want to deal with this at 60 years old. I'm really frustrated that I even have to ask about this in the forum.
The best thing would be to replace all diesel mechanics with AI.
Let's see how far society can go with that!
Is Rosstech considering any solutions to this problem for us?
P.S. My problem was, of course, solved by the 10-second access.
Thank you again, Michael.
Best regards, Udo.
Translated on 07-07-2026, 12:08.
Herbert likes this.
Post08-01-2025, 18:35    Subject: No access permission to diagnostic interface 019 on Golf 8 Quote
Buddy11 wrote:
Is there any possibility that Rosstech might be able to solve this problem for us?
P.S. My problem was, of course, solved by the quick access time of 10 seconds.
Best regards, Udo
Hello, yes, it's in the pipeline, but the collaboration with the VAG Group seems to be quite difficult...
https://community.dieselschrauber.org/en/viewtopic.php?t=31009
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Access Denied: Motor Electric System (31) On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. MSG/WFS Golf 3 1Z: No Connection? On-Board Diagnostics (OBD)
No new posts Chip Tuning Golf IV TDI ALH: No Clutch Upgrade? Diesel Engine Technology
This topic is locked, you cannot edit or reply. OBD3 Diagnostic Interface: Features & Benefits On-Board Diagnostics (OBD)
