| Injector calibration with VCDS | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| dieselschrauber |
Adjust IMA-ISA values – TDI injector calibration with VCDS (injector adaptation)
Anyone working on modern diesel engines will eventually encounter piezo injectors. These high-precision parts are factory-measured and classified into groups – the so-called IMA (Injector Quantity Adjustment) and ISA values (Injector Voltage Adjustment). They describe the individual injection behavior of each valve. Due to manufacturing tolerances, each injector has its own unique characteristics. The engine control unit (ECU) uses these values, along with self-learned correction factors, to optimally calculate the pre-injection and post-injection amounts for each cylinder.
When do IMA-ISA values need to be adjusted?
The adaptation code – where can I find it? The code is directly on the injector. Most of the time, it is a 7-digit value. Exception: 1.2 L engines with Delphi injectors – in this case, there is a 20-digit code present. This value must be converted before being entered, as the control unit only understands hexadecimal values. Conversion table (code on the injector → converted code)
On the injector, it says: W G 7 6 4 8 8 H E 6 F 7 K 7 U 5 2 C Z 0. After the conversion, the result is:
Now, spaces need to be inserted so that a readable string is created. Requirements
Instructions – Adjusting IMA and ISA values using VCDS
Tips
If anything is unclear, consult the official VCDS manual or the relevant forums. See also: Okay, I'm ready. Please provide the German text you want me to translate.
Dipl.-Ing. (FH) Rainer Kaufmann - Original VCDS mit KPower, KDataScope und Dieselschrauber Support Translated on 03-07-2026, 15:19. |
| Ratings - Injector calibration with VCDS | |
Average rating: 0.00 - worst rating: 0 - best rating: 0 - number of ratings: 0 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.068s
