VCDS: HEX-USB CAN adapter not found after update (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post21-07-2025, 20:16    Subject: VCDS: HEX-USB CAN adapter not found after update Quote
Problem: After a VCDS update, a HEX-USB+CAN device (which has been replaced by the HEX-V2) is no longer recognized. The Windows device driver for the HEX-USB+CAN is not installed.
Solution: Install the "legacy drivers." These must be manually selected during the VCDS setup process; they will no longer be automatically installed more than 8 years after the end of production for the HEX-USB+CAN device.
The image shows the English-language VCDS setup; it works the same way in the German version of VCDS.
If you are using Windows 11:
Ross-Tech wrote:
Settings -> Update & Security -> Windows Security -> Device Security -> Core Isolation -> Memory Integrity.
Turn Memory Integrity OFF.
Windows on ARM:
There is no device driver for the original HEX-USB+CAN for Windows on ARM. -> Upgrade to HEX-V2.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Translated on 28-07-2026, 9:54.
Ratings - VCDS: HEX-USB CAN adapter not found after update
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Transmission Control Module Not Found Transmission, Chassis, Body & Interior
No new posts VCDS 16.8.0: Channels Unavailable After Update On-Board Diagnostics (OBD)
No new posts P1640 Error After Update: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Unable to save after update On-Board Diagnostics (OBD)
