Haldex Gen4 Control Unit Replacement
58toho
Post04-10-2026, 20:14    Subject: Haldex Gen4 Control Unit Replacement Quote
"I'm having a problem with the Haldex system on my 2013 Octavia Scout 2.0 TDI. It's not working."
Steuergerät lässt sich nicht auslesen, wird mit VCDS nicht erkannt. Nach der optischen Prüfung, klarer Fall von Wasserrintritt in Folge dessen Platine vergammelt. SoKeep up the good work.
Option 1: Have the control unit repaired, but the vehicle will not be drivable during that time.
Option 2: Find a used control unit.
Now I've seen that there are also replicas of this control unit available, and they're offered at a relatively low price.
Has anyone ever tried this?
My question is, do these control units actually have any software installed on them?
Or are they naked?
The car has already driven over 400,000 kilometers, and I don't know how long the all-wheel drive system has been malfunctioning.
The goal is to get the all-wheel-drive system running at the lowest possible cost.
Are there any user reviews available?
It's about replica engine control units (ECUs) from AliExpress, costing around 100 euros.
Translated on 04-10-2026, 20:17.
58toho
dieselschrauber, Hutfahrer and Turbinchen likes this.
Post03-11-2026, 13:26    Subject: Haldex Gen4 Control Unit Replacement Quote
Okay, and finally, for anyone who might want to try this.
I ordered the control unit from AliExpress.
The delivered control unit was definitely an original part, but it had been meticulously sandblasted, and the labels had been removed.
I assume that the internal components are either new or have been repaired.
I installed it yesterday, and my all-wheel drive is working perfectly again.
The control unit can be accessed and read using VCDS.
Measurement data blocks checked; no errors remain stored, even after a longer drive.
The humming and jerking noises from the rear axle have completely disappeared.
Definitely recommendable for 106 euros.
Translated on 03-11-2026, 18:32.
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Coding Haldex 4 Control Unit Transmission, Chassis, Body & Interior
No new posts Haldex Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Haldex Oil Change: Service & Costs Transmission, Chassis, Body & Interior
No new posts Haldex TT 8N Problem: Troubleshooting Guide Transmission, Chassis, Body & Interior
