3bAFN
04-10-2026, 12:44 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
Hello.
I bought a Caddy 2K two years ago and have been working on it on and off ever since.
Now I was planning to go to the TÜV (German technical inspection), but the brakes on the left rear wheel aren't working at all. The brake caliper moves freely, and the handbrake mechanism is also working.
Fluid is present on all brake calipers except for the rear left one. I then worked my way through all the fittings, all the way to the ABS module, but nothing is leaking there either.
However, if I select the "bleed hydraulic unit" option in the basic settings via VCDS, brake fluid also reaches the rear left brake.
Since I've owned the car, only the right rear saddle has been replaced. Otherwise, no work has been done on the braking system.
It's a 2004 Caddy with the MK70 ABS system.
Do you suspect the problem is more likely related to the control unit or the hydraulic block?
Thank you very much for your ideas.
Sören.
Translated on 04-10-2026, 12:47.
Herbert Profi-Schrauber
dieselschrauber likes this. |
05-10-2026, 9:50 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
How did you attempt to bleed the brakes? Did you apply pressure to the brake fluid reservoir, or did you use the brake pedal? Was the ignition on or off during the process?
It almost looks like the inlet valve for the brake on the rear left side of the ABS module is blocked. However, this should only happen when the system is activated.
Can you individually address the valves in the ABS module during an actuator diagnosis? If so, do they sound the same?
Don't forget to run the Autoscan!
Translated on 05-10-2026, 10:03.
Joined: 04/12/2002 Posts: 18137 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
05-10-2026, 15:23 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
Please also check the brake hoses and the connection to the brake caliper for leaks, as brake fluid can leak out and air can get in, not always in both directions at the same time...
Aluminum O-rings, in particular, can sometimes look visually fine, even though they are partially corroded and damaged.
Translated on 05-10-2026, 15:24.
Profile PM WWW Garage |
3bAFN
dieselschrauber, Herbert, Steffen G and Turbinchen likes this. |
21-10-2026, 18:10 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
The cause of the problem was a defect in the ABS module.
I was unable to get any brake fluid to the cylinder, whether with the ignition on or off. The pedal always felt like the system was free of air and closed.
I also couldn't make any progress with the actuator diagnostics. I couldn't find anything conclusive there.
ABS module replaced and everything is working fine.
Thank you.
Translated on 21-10-2026, 18:14.
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2558 Karma: +592 / -0 Location: bei Zwickau
22-10-2026, 18:00 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
I've never experienced anything like that before.
Thank you for the report.
Translated on 22-10-2026, 18:00.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-10-2026, 18:49 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
"Something you might know from Ford."
Translated on 22-10-2026, 18:49.
Profile PM Garage |
3bAFN
23-10-2026, 10:20 Subject: Brake Fluid Leak Caddy 2K - Rear Left |
Rüdi wrote: | | Known from Ford |
Do you happen to know exactly what's defective in the ABS module?
Translated on 23-10-2026, 10:20.
