Water Pump Replacement VW Sharan TDI (AC Removal?)
Dicktier
Post07-09-2003, 18:35    Subject: Water Pump Replacement VW Sharan TDI (AC Removal?) Quote
Hello everyone!
I recently bought a SHARAN TDI (with a 1Z engine) for my loved one. Unfortunately, the water pump failed the very next day. icon_cry.gif
When I picked up the car from the BOSCH service center, I was presented with a bill for €306!
I was told that parts of the air conditioning system had to be removed.
My question is: was this really necessary, or is the workshop just trying to make more money?
I'm asking because the same workshop previously performed 'repairs' on a friend's car that weren't actually necessary.
Perhaps someone here is familiar with the Volkswagen Sharan and can help me.
Sure, no problem! Here's the translation:
'Thank you in advance!'
Translated on 28-09-2026, 11:55.
Michael II
Post07-09-2003, 18:48    Subject: Water Pump Replacement VW Sharan TDI (AC Removal?) Quote
If I remember correctly, you need to disconnect the compressor for that. But that's a job that takes about 5 minutes.
To the best of my knowledge, you need to do the following:
- Remove and install covers.
- Drain and refill the coolant.
- Install and remove the V-ribbed belt.
- Remove and reinstall the compressor (this can be done without any other work on the refrigeration circuit).
- Remove and reinstall the headlight.
- Remove and reinstall one engine mount.
Tschüss
Michael II
Translated on 28-09-2026, 11:57.
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wiring diagram for climate control system, G3.1Z Diesel Engine Technology
No new posts Is the climate compressor blocked? Transmission, Chassis, Body & Interior
No new posts Kickdown Switch: Diesel & AC System Repair Diesel Engine Technology
No new posts Running fan? - Audi 80 TDI - 1Z with air conditioning - 1994 Diesel Engine Technology
