Audi A3 Steering Wheel (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Karma: +796 / -0   Thank you, like it!
Post04-06-2002, 16:50    Subject: Audi A3 Steering Wheel Quote
On my A3, manufactured in 1998, the steering unfortunately has some play. One can turn the steering wheel approximately 4-5mm in either direction without anything moving in the wheels or the steering gear.
This isn't dramatic, but at high speeds, it's a bit annoying, and you're always driving slightly "snake-like".
The parts that cause the noise are the interlocking square tubes between the 1st and 2nd cross-joint of the steering shaft in the footwell. These were already replaced once for the same reason, unfortunately, they seem to only last for about 30,000 km before the steering components become noticeably worn again.
Solution thanks to Michael II:
At position A3 before the frame number 8L VA 057 550, the problem potentially exists, after which there is an improved steering column.
Anyone who is also annoyed by consuming 1 meter more of road width at 200 km/h can mount a split clamping ring on the square tube:
Part Number 1J0 419 838A
Warning: Has the new steering column been installed, which starts to rattle slightly later? If so, the clamping ring will not fit!
One can then properly adjust the clamping ring, but this requires appropriate tools and a steady hand.
Hello, Rainer
Ratings - Audi A3 Steering Wheel
No new posts Steering play VW T5/T6 (solution) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts 2L TDI mit 170 PS im Audi A4 B7 Diesel Engine Technology
No new posts Audi A8 4.0 TDI Diesel Engine Technology
