AAZ Glow Plug Timer Control
Treckerfahrer
Post29-11-2003, 22:11    Subject: AAZ Glow Plug Timer Control Quote
I hope someone can help me with the glow plug control on my AAZ engine. (I know, it's a diesel dinosaur, but it's the ancestor of all TDIs).
I've noticed that the glow time is always consistently around 8-9 seconds, regardless of the engine's coolant temperature.
I suspect the thermocouple is broken (although, in theory, they shouldn't break).
Can anyone tell me what the expected resistance values of the temperature sensor should be, where it is located, and what the pin configuration is?
'Where is the glow plug control unit located in a Golf 3 with an AAZ engine? I haven't been able to trace the cables yet. I hope it's not broken, because it does seem to be glowing.'
Thank you for your help.
Translated on 29-09-2026, 23:23.
haehnlein
Post30-11-2003, 13:58    Subject: AAZ Glow Plug Timer: How to Adjust It Quote
Treckerfahrer wrote:
Where is the glow plug control unit located in a Golf 3 with an AAZ engine? I haven't been able to trace the cables properly yet. I hope it's not broken, because it does seem to be glowing.
It sounds like a glow plug relay. You can usually find it in the fuse box (where you'll also find the relays for the starter, etc.).
____________
Kein Auto mehr!
Translated on 29-09-2026, 23:24.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
