Motor Tuning besides a chip? 1.9 TDI 81KW
durts
Post15-01-2004, 9:05    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Quote
Hello everyone!
I am a new member and would like to introduce myself briefly. My name is Alexander and I come from the beautiful green Styria, near Graz (Austria). My current vehicle is a red Seat Ibiza, manufactured in 2000 - engine AFN 1.9 TDI 81/110 [KW/PS].
I have already had a sports air filter and a chip tuning done for some time. My current performance, according to the Bosch dyno, is 109 kW (148 hp) and a maximum torque of a proud 358 Nm at approximately 100 km/h in fifth gear. Due to this performance improvement, I still had to have the suspension rebuilt (shock absorbers, control arms, and sway bar).
My question(s) now to you would be:
I would like to extract even more 'power' from this vehicle - I am considering making any modifications that are possible. I was thinking about having a different air-to-water cooler installed. Either the one from the 1.9 TDI PD 150PS engine or the one from the 2.5 V6 TDI. Which one is the better option? With which additional power output could I expect to achieve? Are there any other ways to get something out?
I hope someone will give me an answer!
Okay, thank you in advance!
durts
Marco
Post15-01-2004, 9:20    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]Hallo durts,
Schau mal bei den Fachartikeln rein. /viewforum.php?f=10
Mc_Givertechnik
2010 Volkswagen T5
Post15-01-2004, 9:21    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
Hallo Durts!
Es ist schön, auch einen Steirer hier zu finden, servas!
Zu deiner Geschichte:
Das Thema "Sinn und Unsinn eines großen Ladeluftkühlers" ist in einem Fachartikel genau beschrieben. Auch die Geschichte mit dem Sportluftfilter ist im Fachartikel genau beschrieben.
Eine Möglichkeit besteht noch im Tausch der Einspritzdüsen. Man nehme die vom 150 Psigen T4, aber da gibt’s auch einen Fachartikel (Düsentuning)
icon_eek.gif Was zu erwähnen wäre:
Bedenke immer, dein 1,9 TDI Motörchen ist ein empfindliches Uhrwerk, dessen Lebensdauer durch trastische Tuningmaßnahmen vehement verkürzt wird. Bedenke auch, dass das Getriebe deines IBIZA nur für bestimmte Drehmomente ausgelegt ist. Wenn Geld keine Rolle spielt, kannst du tunen so lange bis alles zerbröselt, aber sonst würde ich schön langsam die Bremse ziehen. Ist nur ein Ratschlag. Da ich davon ausgehe, dass nichts von den Umbauten typisiert ist, hat dein Auto auch keinen Haftpflichtschutz mehr. Die grünen Kapperlständer wissen nun mittlerweile auch schon recht gut bescheid und holen sich auffällige Dieselfahrzeuge an die Brust. Ich weiß von Fällen, da wurde das Auto zur Untersuchung beschlagnahmt, der Lenker angezeigt, und zu einer bedingten Haftstrafe verurteilt. Ergebnis, man ist vorbestraft, es kostet viel Kohle, für nix und wieder nix.
Kauf dir lieber einen V6 TDI und mach da ein bisserl was. Hält länger, kostet das Gleiche und ist sicherer icon_rolleyes.gif
Die besten Grüße, Peter
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Mc_Givertechnik
2010 Volkswagen T5
Post15-01-2004, 9:30    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
Nur zur Info.
Bei welchem Bosch Dienst hast du deine Leistung messen lassen und was kostet das?
Grüße, Peter
durts
Post15-01-2004, 16:13    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]Wo genau ich das überprüfen hab lassen da müsste ich mal daham nachschauen. Es hat so um die 70€ gekostet bin mir aber nicht mehr ganz sicher ... werd dann mal nachgucken.
grüße durts
Post15-01-2004, 16:40    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
das Thema wurde schon ausgiebigst diskutiert, daher möchte ich Dich bitten, die Suchfunktion zu nutzen.
Alles weitere kostet unverhältnismäßig bei fragwürdiger Haltbarkeit. Dann doch besser nen gebrauchten Porsche kaufen.
Grüße, Rainer
Arne
Post15-01-2004, 16:41    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]Hi durts,
ich gebe Mc_Givertechnik recht, Dein Auto scheint doch satt Leistung zu haben, bei
dem Gewicht doch optimalst. Wenn Du allerdings gerne schraubst und auch genügend
Kleingeld liegen hast:
- Turbolader (vnt 17 o. VNT 19)
- die besagten T4 Düsen
- Pumpenkolben 12mm (wurde vorgestern erst drüber geredet)
Dann sind sicher 200 PS drin, nur ob die Standfest sind... kannste Dir sicher selbst denken.
Gruss,
arne (mit dem Chip und den T4 Düsen)
durts
Post15-01-2004, 19:22    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]so habe nun nachgeguckt: 70,20 euronen hat das überprüfen gekostet. war bei koch.at - 8020 graz - karlauer gürtel 4
grüße durts
durts
Post15-01-2004, 19:45    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]hi!
wenn ich die düsen vom t4 einbaue ... wieviel würden die denn kosten?
grüße durts
Andy
Post16-01-2004, 0:09    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
4 Düsen im Austausch ca. 450 bis 500 Euro; 4 neue Düsen ca. 1000 bis 1100 Euro.
Gruß Andy
Mc_Givertechnik
2010 Volkswagen T5
Post16-01-2004, 7:17    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
Und bei Dieselsend kostet der ganze Satz Düsen, wenn Motopal € 43.-, wenn von Bosch € 91.-. Aber wie gesagt, nur die Zapfendüse alleine. Wen du aber den ganzen Düsenhalter haben willst, kostet das € 130.- bis € 160.- je nach Type.
Grüße, Peter
durts
Post16-01-2004, 8:52    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]aha danke!
find ich aber nicht so schlimm!
grüße
durts
Post16-01-2004, 9:09    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
@ Peter
Henzo hat doch nur noch Zapfenduesen !?
Was nutzen Preise fuer ZD, wenn wir alle LochDuesen haben ??
Warum hat Henzo keine Lochduesen mehr, frueher haette er welche !
Mc_Givertechnik
2010 Volkswagen T5
Post16-01-2004, 9:14    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]
A, ha. Werd gleich suchen gehen.
Andy
Post16-01-2004, 10:48    Subject: Motor Tuning besides a chip? 1.9 TDI 81KW Translating...
[Translating...]Hi,
vor ein paar Monaten habe ich bei Henzo mehrmals wegen Düsen für meinen AFN angefragt.
Leider habe ich nie eine Antwort bekommen, daher gehe ich davon aus, dass er keine Lochdüsen mehr vertreibt.
Gruß Andy
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gibt es z.Z. bei VAG noch nen Wastegate TDI ausser dem 1.4 Diesel Engine Technology
No new posts Garanties for Engine Tuning Diesel Engine Technology
No new posts Engine tuning from the perspective of a legal expert Diesel Engine Technology
No new posts Engine Tuning 3 Liter Lupo TDI Pump Injector Diesel Engine Technology
