mersente wrote: |
Hello Ulf, in your case, that might be true, but there are also engines that have multiple sensors for coolant temperature. For example, the function of the radiator fan is monitored, but this is probably less common in diesel engines.
Is your power supply two-pole or four-pole? |
The valve is 2-pole, unlike the (water) double valves that I am familiar with, which are 4-pole.
I actually had some time today to connect the VAGCOM device and use a hot air gun to heat up the various sensors (in order to, among other things, verify the association of the measurement value fields in my label file).
The water temperature sensor, which shows a reading of 90° when measured with a 330 Ohm resistor, also causes one of the temperature fields in the VAGCOM diagnostic tool to increase when the engine is warmed up.
According to this, this single power supply apparently provides power to the EDC and the AI.
Thank you for your responses!
