Is the Golf ALH engine not getting enough diesel?
totto2k
Post27-03-2004, 11:52    Subject: Is the Golf ALH engine not getting enough diesel? Quote
I drive a Golf 4 TDI with 90 horsepower, ALH engine (76,000 km).
The car has already had a new mass airflow sensor (MAF sensor) installed, which, according to the diagnosis from VW, was defective. However, the overall performance was still very low; I test-drove three other similar Golfs for comparison.
Now I've tested a tuning module, and with that, the engine really comes into its own.
Now, my question is: Which components are still responsible for the fuel injection amount, and how can I test them? icon_question.gif
Unfortunately, the computer does not log any errors.
Of course, I'd rather not use a tuning box; at the moment, it seems to be compensating for a fault in a sensor.
Thorsten.
Marco
Post27-03-2004, 12:08    Subject: Is the Golf ALH engine not getting enough diesel? Quote
Hello Thorsten,
I find your approach to troubleshooting a bit strange!
Why don't you try the normal approach and first log the following:
1. Boost pressure.
2 LMM values.
3 Injection quantity
totto2k
Post28-03-2004, 12:36    Subject: Is the Golf ALH engine not getting enough diesel? Quote
Thank you for the tips.
I can now rule out turbo boost; otherwise, the car wouldn't be performing so well with the tuning box installed.
Perhaps I should have the LMM (lambda sensor) checked again at VW, as it should still be under warranty.
Thorsten.
Martin R
Post02-04-2004, 18:54    Subject: Re: Is the ALH engine in my Golf not getting enough diesel? Quote
Which sensors are still responsible for the fuel injection amount ?
The water temperature sensor in the EDC might be malfunctioning.
If the 'reported' temperature is too high (but still within a possible range), the engine will also not deliver its full power.
This is usually not indicated by the control system or stored in the error memory.
You can only detect the error if it is currently present and you are reading the measurement value at that moment.
I don't know if it's the same with your vehicle, or even if it's possible. But in our case, it was the same (although it was a truck - but the 'basic structure' of the EDC is probably similar).
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Golf III AFN Engine: Low Power? Troubleshooting Diesel Engine Technology
No new posts Golf 4: Low AC Compressor Pressure - Troubleshooting Transmission, Chassis, Body & Interior
No new posts Golf 5 TDI: Jerking & Low Power - Troubleshooting Diesel Engine Technology
No new posts AHF 81 kW Machine: Who Still Uses It? Diesel Engine Technology
