flightmaster Guest
27-06-2004, 16:32 Subject: Rear Brake Disc Replacement for VW Golf 4 |
Hello Volkswagen enthusiasts,
After replacing the rear brake pads and rotors today, the overhaul of the entire rear braking system is scheduled for soon.
My question:
Can the glass panes be removed using common tools (rust remover and a hammer), or are specialized tools (e.g., suction cups) required?
I hope the glass pieces can be easily removed after the saddle is disassembled.
The windows on the car were heavily rusted and could only be removed with force.
The rear wheel bearing/disc mount looks a bit less robust.
Thank you in advance...
Translated on 05-08-2026, 22:35.
wbuchi82 Blaumann
Joined: 11/10/2003 Posts: 88 Karma: +9 / -0 Location: Österreich/Steiermark/Haus
27-06-2004, 19:55 Subject: Rear Brake Disc Replacement for VW Golf 4 |
Hi!
Okay, the rear ones are definitely not a problem. I don't know how bad the rust is on yours, but on mine, I also had to do some hammering. No special tools are needed either, possibly just something to retract the piston. Currently, the front brake discs and pads are next on my list  .
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Translated on 05-08-2026, 22:36.
Profile PM Email |
wolfi_b Profi-Schrauber
29-06-2004, 10:09 Subject: Rear Brake Disc Replacement for VW Golf 4 |
To push the pistons back, you may need to simultaneously rotate and press. In my case, the key of my small angle grinder fit perfectly there  . 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 05-08-2026, 22:37.
Jürgen Guest
29-06-2004, 16:10 Subject: Rear Brake Disc Replacement for VW Golf 4 |
I replaced the windshields on the front and rear of the car during Easter break - short.
A small hammer (200g) was perfectly sufficient.
Translated on 05-08-2026, 22:38.
Gremlin Guest
29-06-2004, 18:12 Subject: Rear Brake Pad Replacement - VW Golf 4 Guide |
sometimes yes, look HERE and for the result HERE .
CU Gremlin.
Troubleshooter Guest
01-07-2004, 15:52 Subject: Rear Brake Disc Replacement for VW Golf 4 |
Hi.
You need to rotate the pistons at the back, but you don't need any special tools for that; a C-clamp, a pipe wrench, and a bit of feel are enough.
Greetings,
Cheers,
Warmly,
Sincerely,
(or simply)
Hey,
Love, (if appropriate)
XOXO, (if appropriate)
@Gremlin:
Hopefully, such a horrific scenario can be avoided in the case of an IVR  .
Translated on 05-08-2026, 22:40.
Gremlin Guest
01-07-2004, 19:09 Subject: Rear Brake Disc Replacement for VW Golf 4 |
@Gremlin:
It's not always the case... that one was incredibly difficult... the other side went down easily.
Well, I drove a Ford and then walked home.
CU Gremlin.
Translated on 05-08-2026, 22:41.
Julian Guest
01-07-2004, 19:37 Subject: Rear Brake Disc Replacement for VW Golf 4 |
I can confirm. These aftermarket brake discs (which are not factory-installed) tend to rust very easily and extensively. Sometimes, it's so bad that the wheel won't even come off with gentle persuasion... let alone getting the wheel nuts off, which requires a 2-meter steel pipe extension and your own body weight on the wrench...
Translated on 05-08-2026, 22:42.
flightmaster Guest
01-07-2004, 23:11 Subject: Rear Brake Disc Replacement for VW Golf 4 |
Thanks for the answers... By the way, I always use a torque wrench to tighten the rear brake caliper pistons... it works great.
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 05-08-2026, 22:43.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
02-07-2004, 15:43 Subject: Rear Brake Pad Replacement - VW Golf 4 Guide |
flightmaster wrote: | | The windows on the car were heavily rusted and could only be removed with force. |
I have developed a simple and secure procedure for such cases:
You use a flexible tool to create a roughly 3 cm long slot radially into the brake disc. Then, you position a chisel and, using a hammer, strike the chisel radially into the disc. The disc will then crack and can be easily removed -> this method works 100%  . ____________
Kein Auto mehr!
Translated on 05-08-2026, 22:44.
03-07-2004, 7:30 Subject: Rear Brake Disc Replacement for VW Golf 4 |
Hey guys!
I always spray the wheel hub with a little bit of copper grease before installing a new brake disc, and it actually works quite well.
Sincerely,
(or simply)
Cheers,
Translated on 05-08-2026, 22:45.
