Control Unit 46: Suddenly Unreachable?
Martha
Post30-08-2004, 20:25    Subject: Control Unit 46: Suddenly Unreachable? Quote
Hello everyone,
Last week, I successfully changed the settings of the comfort control unit on a new imported Seat Leon 1.9 TDI (engine code unknown) using VAG-Com. The automatic locking function was successfully disabled. Today, I wanted to disable the individual door opening feature with the same equipment, but I can no longer connect to device 46. All other functions work as usual. Also, the control unit itself still works, because the central locking and power windows are functioning properly.
Where could the error be?
Martha.
Translated on 05-08-2026, 10:05.
Gremlin
Post30-08-2004, 20:47    Subject: Control Unit 46: Suddenly Unreachable? Quote
Pull the relevant fuse (usually labeled 'interior light'), wait 30 seconds, and then reinsert it.
I'm not sure why, but the device can sometimes be a bit temperamental.
CU Gremlin.
Translated on 05-08-2026, 10:06.
Uwe@Ross-Tech
Post31-08-2004, 5:30    Subject: Control Unit 46: Suddenly Unreachable? Quote
Yes, this tax software, similar to a computer, sometimes needs a 'reboot'. icon_smile.gif It runs constantly, even when it's supposedly turned off.
-Uwe-
Martha
Post02-09-2004, 8:50    Subject: Control Unit 46: Suddenly Unreachable? Quote
Hello Uwe, hello Gremlin,
Thank you for the interesting suggestions. I probably won't be able to try them out until next week. I'll keep you updated.
Martha.
Translated on 05-08-2026, 10:07.
Martha
Post06-09-2004, 9:02    Subject: Done! Success! Achievement! Quote
Hello Gremlin, hello Uwe,
Bingo! The tip about securing the interior lighting worked. Device 46 is reachable again. Adjustments have been made!
Thank you very much!
Translated on 05-08-2026, 10:08.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN suddenly no longer starts. Diesel Engine Technology
No new posts Alte VAG-COM Version 409 läuft plötzlich nicht mehr ric... On-Board Diagnostics (OBD)
No new posts Steuergerät wird nicht mehr erkannt Diesel Engine Technology
No new posts VP37 control unit no longer controls the pump On-Board Diagnostics (OBD)
