Clutch Squeal: Causes and Solutions
highspeed1
Post08-09-2010, 10:46    Subject: Clutch Squeal: Causes and Solutions Quote
Hello, I have a Mazda 6, model year 2003, with a 2.0 diesel engine.
I've noticed that there's a strange noise when I press the clutch pedal while driving. It's not very loud, and it doesn't happen when the car is stationary or idling. It only makes the noise briefly when I engage the clutch while driving. Could it be something serious, or is it just the clutch?
And another question for the experts: Is it permissible for a diesel vehicle to have an aftermarket DPF (Diesel Particulate Filter) installed?
While shifting gears on the highway, a bright, white cloud of smoke appeared.
leave behind?
best regards
Martin.
Translated on 08-09-2026, 2:45.
Post08-09-2010, 10:51    Subject: Clutch Squeal: Causes and Solutions Quote
Hello Martin,
So, it only squeaks very briefly when engaging the clutch while driving. Could it be something serious? Or is it just the clutch?
Regarding the Mazda specifically, I'm not aware of any common issues. However, it's conceivable that the engine could be tilting in the engine mounts when the clutch is engaged, which could cause the connecting parts or flexible components of the exhaust system to squeak. For example, I once had a G2 where a hemispherical graphite gasket between the exhaust manifold and the exhaust pipe was squeaking.
White smoke is normal as long as it's steam. However, if it's oil fumes or coolant, which can be identified by the smell, it should not occur, whether the vehicle has a DPF (Diesel Particulate Filter) or not.
Translated on 08-09-2026, 2:47.
highspeed1
Post08-09-2010, 12:39    Subject: Clutch Squeal: Causes and Solutions Quote
Thank you very much!
Translated on 08-09-2026, 2:48.
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Noise: Causes and Solutions Diesel Engine Technology
No new posts Noises when the front axle is lowered Transmission, Chassis, Body & Interior
No new posts Geräusche nach dem Einkuppeln Transmission, Chassis, Body & Interior
No new posts Clutch pedal squeak Diesel Engine Technology
