Audi A4 TDI: Fahrenheit Conversion (99)
Aladin
Post10-09-2004, 18:58    Subject: Audi A4 TDI: Fahrenheit Conversion (99) Quote
'You spend some time searching for these stupid climate codes, and when you finally find them, you suddenly encounter a setting that isn't even described in them. So, I have a 1999 A4 Avant TDI (facelift model, with a different Climatronic panel). Since I've been messing around with the hidden and supposedly secret climate codes, the outside temperature and climate temperature displays on my car have been switched to Fahrenheit. I've already found the conversion tables, but it's a hassle in the long run. Is there a way to switch the displays back to Celsius?'
Please help.
Thank you!
Translated on 16-10-2026, 3:18.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post11-09-2004, 15:14    Subject: Audi A4 TDI: Fahrenheit Conversion (99) Quote
Sure, try it with:
By simultaneously pressing the 'ECON' and 'AUTO' buttons, you can toggle the display between °C and °F.
(Golf Climatronic)
Try at your own risk, good luck!
Translated on 16-10-2026, 3:19.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Tire Size: 195/60 vs. 195/65 Transmission, Chassis, Body & Interior
No new posts TDI Engine Swap: Replacing 1.8 ADZ Engine Diesel Engine Technology
No new posts General utility of PD oil instead of 505.00? Diesel Engine Technology
No new posts Cold Cleaner vs. Diesel: A Sustainable Alternative? Diesel Engine Technology
