Polo: Brake Caliper Bolt Torque Specs
eike
Post12-10-2004, 22:04    Subject: Polo: Brake Caliper Bolt Torque Specs Quote
Hey fellow mechanics,
Does anyone know the torque specifications for the caliper mounting bolts on a 2001 Polo SDI? Do you need to use new bolts, or can the old ones be reused?
Thank you and best regards.
Eike.
PS: Can the brake cylinder be simply pushed back in, or is there anything to be aware of?
Translated on 26-09-2026, 8:20.
Michael II
Post13-10-2004, 9:58    Subject: Polo: Brake Caliper Bolt Torque Specs Quote
Front wheel brake system (Girling/Lucas): 35 Nm, replace screw.
Front wheel brake with guide pin: 25 Nm. The guide pins can be reused.
Tschüss
Michael II
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Noises & Sounds - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Torque Specs: Pulley & Seal for 1Z Engine Diesel Engine Technology
No new posts Tightening Torque: 16V PD Camshaft Diesel Engine Technology
No new posts Crankshaft bolt torque specification ALH G4 Diesel Engine Technology
No new posts Cylinder Head Bolt Torque Specs 1Z Diesel Engine Technology
