{SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Holger247
Post04-10-2004, 11:11    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Quote
For some time now, I've been noticing a clicking sound in the driver's seat, for example, when making sharp turns or when braking hard. From my perspective, the seat also seems to lean forward slightly. The car has 120,000 km.
If you wiggle the seat, you can see that the rollers in the seat rails have some play, but this is almost the same on my friend's A3 (with 20,000 km), but there it doesn't make a clicking sound.
Does anyone have any ideas?
I read somewhere that a weld on the A4 had broken. Can this also be the case here?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Michael II
Post04-10-2004, 12:32    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]
hast du die Easy Entry Funktion?
Wenn ja:
Die Geräusche können auftreten, wenn der Sitz seitlich belastet wird, zum Beispiel beim Hinsetzen, Aufstehen oder wenn man durch eine Kurve fährt.
Ursache:
Schutzkappe an der Easy Entry Entriegelung fehlt.
Lösung:
- Lehne entriegeln und nach vorn klappen.
- Wenn die Kunststoff Schutzkappe an der Easy Entry Entriegelung ( seitlich außen am Sitz ) fehlt, muss eine neue Schutzkappe eingebaut (geclipst) werden.
Tschüss
Michael II
DocSnydor
Post04-10-2004, 13:18    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
Wenn ja:
Und wenn nein? Habe das Problem auch...
AndreasG
Post04-10-2004, 13:56    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
http://www.picupload.net/files/20040410/1096890490.jpg
Die komplette Schweißnaht war durch. Lustig auch der Versuch von VW das Knarren
zu beseitigen: Die weißen Reste des Sprühöl sind noch gut zu sehen.
Karma: +437 / -0   Thank you, like it!
Post04-10-2004, 14:08    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]
icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif
Ich hoffe du hast denjenigen direkt k.o. geschlagen! So etwas kann ja nun absolut ganz und garnicht angehen....
Holger247
Post04-10-2004, 14:15    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]
uuups, das sieht ja übel aus. Werde gleich mal nachsehen, ob das bei mir auch gebrochen ist.
Was hast Du dann gemacht? Geschweißt? Oder neues Sitzgestell?
Kann man das einfach schweißen? Wegen Seitenairbag?
@MichaelViewing profile: Michael II: Habe einen 4 Türer, also keine Easy Entry Sitze.
GIV - 98 - ALH
Touran 5T 2.0 TDI
AndreasG
Post04-10-2004, 14:17    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]VW wollte mir die Reparatur etwas günstiger machen (ca. 250Euro für das Sitzgestell),
aber ich hatte dankend abgelehnt. Die reparieren mir nichts mehr. Ich habe den Sitz
ausgebaut und schweißen lassen. Jetzt ist er so ruhig wie am ersten Tag.
Edit: Habe auch einen 4 Türer. Den Stecker des Seitenairbag kann einfach rausgezogen und mit einem Kurzschlußstecker gesichert werden. Die Anleitung zum Ausbauen hatte ich
hier aus dem Forum.
Holger247
Post04-10-2004, 14:34    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]
Habe gleich mal nachgesehen: Bei mir ist die Schweißnaht noch o.k. - puh Glück gehabt. Allerdings ist das Knacken acuh noch immer vorhanden.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Julian
Post04-10-2004, 17:40    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]Naja mit EasyEntry hat dieses Problem meist wenig zu tun. Bei meinem Golf4 wurden die Sitzschienen getauscht, erst dann war wirklich Ruhe im Auto...
Holger247
Post04-10-2004, 17:46    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]
@Julian:
kann man die Sitzschienen tauschen? Die sind doch Bestandteil der Karosserie bzw. mit dieser verschweißt, oder?
War das bei Dir durch Verschleiß oder von Anfang an vorhanden?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Julian
Post04-10-2004, 17:54    Subject: {SUBJECT}: Cracking the seat in a Golf IV {VERB}: Cracking {OBJECT}: seat {PREPOSITIONAL_PHRASE}: in a Golf IV Translating...
[Translating...]Soweit ich noch weiß, sind die am Boden verschraubt. Muß man auch lösen um den Sitz
auszubauen.
Hatte ein 12/98er Modell, nach etwa 2 Monaten fing der Geräusch-Terz an und nachdem einige Mechaniker ihre Silikonspraydose schlucken durften (der Silikonfett-See unter meinen Sitzen war unerträglich) bequemte sich VW nun doch, mir die Sitzschienen auszutauschen. Danach war endgültig Ruhe...
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question about the location of the crankshaft sprocket Diesel Engine Technology
No new posts Airbag-Sitz gegen Recaro tauschen Transmission, Chassis, Body & Interior
No new posts Pinout of the MFA (Golf IV) Transmission, Chassis, Body & Interior
No new posts Wassereinbruch GolfIV Transmission, Chassis, Body & Interior
