AFN: Injection Timing & Turbo Pressure - Questions?
Go to page: 1, 2  Next
frebert
Post21-10-2004, 8:11    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Hello Forum users,
I have read several posts with great interest about the start of injection (pump settings, etc.), boost pressure, and tuning. With this knowledge, I decided to work on my own van. It's a T3 icon_biggrin.gif with a 1.9 AFN engine, and according to the seller, it has been chip-tuned.
So, I connected a laptop with VAG-Com and logged data from groups 3 and 4.
What seems strange to me is the boost pressure! Shouldn't it be going up to 1.8 bar?
Could it be that the issue is related to my modification of channel 3, where I tried to disable the EGR system as much as possible by entering the highest possible value?
Thank you for your contributions icon_wink.gif.
Best regards, Frebert.
Here are the logged data icon_question.gif: (Sorry for the poor formatting, but I don't currently have the ability to upload a file).
/min mg/R mg/R % BTDC BTDC %
882 390 390 54.6 2.4 2.4 56.2
882 390 380 54.6 2.4 2.2 60.6
861 390 400 54.6 2.4 2.6 60.2
882 390 385 54.2 2.4 2.4 62.2
861 390 395 55.4 2.4 2.6 60.6
861 390 390 55.4 0.9 0 2.8
987 405 515 19.9 2.4 2 57
840 390 450 31.5 2.4 2.4 61.8
861 390 460 50.2 2.4 2.6 61
882 390 390 56.6 2.4 2.6 57.8
882 390 385 55.8 2.4 2.6 58.6
861 390 395 55.8 2.4 2 61
861 390 385 55 2.4 2.4 57.4
882 390 385 55 2.4 1.8 60.2
987 625 465 19.9 4 3.3 66.9
987 805 515 19.9 5.3 7 66.9
1491 740 565 19.9 0.9 2.2 46.2
1302 350 550 4.8 4.6 2.2 72.1
1092 685 505 19.9 4.8 4.6 67.3
1323 815 555 19.9 7.9 10.1 66.1
1659 740 695 19.9 6.2 7.5 66.9
2037 775 855 19.9 1.5 2.2 2.8
1596 610 575 19.9 2.2 1.8 71.7
1596 850 720 4.8 9.9 10.3 80.5
1869 850 975 4.8 7.7 7 82.5
2268 850 935 4.8 8.8 8.1 85.7
2646 850 960 4.8 11 10.6 93.6
3024 850 985 4.8 13.4 13.6 90
3381 850 985 4.8 15.2 15.2 94
3696 850 945 4.8 16.7 15.6 96.4
3969 850 925 4.8 2 0 24.7
2667 850 825 4.8 10.8 10.8 80.9
2856 850 915 4.8 11.4 11.4 88.9
2961 850 975 4.8 12.1 13.2 83.7
3087 850 1000 4.8 13 13.4 89.6
3045 370 540 4.8 0 0 20.7
2982 355 430 4.8 0.2 0 19.5
2835 350 415 4.8 0.9 0 18.3
2709 350 415 4.8 1.1 0 17.5
2583 350 420 4.8 1.3 0 17.1
2457 350 425 4.8 1.3 0 16.7
2352 350 430 4.8 1.5 0 16.3
2247 350 430 4.8 1.5 0 16.3
2142 350 440 4.8 1.5 0 17.1
2058 350 450 4.8 1.5 0 17.5
1974 350 455 4.8 1.5 0 17.5
1890 350 455 4.8 1.5 0 17.1
1827 350 460 4.8 1.5 0 16.7
1743 350 460 4.8 1.3 0 16.7
1680 350 460 4.8 1.1 0 16.7
1596 350 465 4.8 0.9 0 16.7
1512 350 470 4.8 0.9 0 16.7
1491 360 445 4.8 12.1 6.8 96.4
1533 850 640 4.8 11 11 82.5
1638 850 875 4.8 10.1 9.9 82.1
1827 850 1070 4.8 8.6 8.4 81.7
2016 850 960 4.8 8.1 7.7 84.5
2226 850 970 4.8 8.6 8.4 81.7
2415 850 1005 4.8 9.2 9 83.7
2604 850 1010 4.8 10.6 10.8 88.1
2814 850 995 4.8 11.7 12.3 88.5
3003 850 985 4.8 13 13.4 89.6
3192 850 970 4.8 14.3 14.3 91.6
3360 850 960 4.8 15.4 15.4 89.6
3528 850 940 4.8 16.1 16.1 90.8
3675 850 920 4.8 1.1 0 22.3
2394 350 500 4.8 0.9 0 16.7
2394 350 455 4.8 0.9 0 16.7
2352 350 430 4.8 0.9 0 16.3
2310 350 435 4.8 1.1 0 16.3
2247 350 435 4.8 1.1 0 16.3
2184 350 450 4.8 0.9 0 16.7
2121 350 445 4.8 0.9 0 17.5
1995 350 455 4.8 0.9 0 17.5
1,9 l AFN mit Schick Wasser LLK im T3
Translated on 11-08-2026, 5:11.
Post21-10-2004, 8:22    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
You have logged the air mass and injection start.
But there's nothing to see regarding the boost pressure icon_wink.gif.
Translated on 22-10-2026, 8:46.
Marfan
If you want us to provide information about your boost pressure, you need to log the data from group 011.
Your LLM metrics look good.
Best regards.
Translated on 22-10-2026, 8:47.
Post21-10-2004, 8:51    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
If we're already learning about logging icon_wink.gif (please don't misunderstand icon_smile.gif),
At the start of injection, it is logically necessary to also record the throttle position, or the amount of fuel injected.
Because when the gas percentage is 0%, nothing is usually injected. In this case, the `S_Beginn` value might be present in the log, but it's not physically relevant (since nothing is being injected) and therefore shouldn't be taken into account.
frebert
Post21-10-2004, 9:08    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
I'm going to log that 011 issue right away (after work)!!
And then post it again.
What about the injection start? Is it correct? According to the TDI timing checker, it's slightly earlier than the ideal timing. However, according to forum posts, this isn't necessarily bad, as it can result in quicker response. Am I understanding this correctly?
I can adjust channel 4 through adaptation so that the start of injection can be set up to 6 degrees BTDC and even a bit further towards earlier timing! Is this harmful to the engine? According to the specification list for the AFN engine, the injection timing should be between 2 degrees ATDC and 4 degrees BTDC at idle icon_question.gif icon_question.gif.
Bei 6 BTDC läuft der motor minimal rauer, spricht aber viel besser auf Gas an und regelt schneller in die Leerlaufdrehzahl zurück. Durchzug ist subjektiv besser, hab aber keinen beschl. TIt is done.
Thank you very much.
Frebert.
Translated on 22-10-2026, 8:49.
Post21-10-2004, 9:28    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Was the box warm when you logged it?
My 1Z is injecting fuel 3 degrees before top dead center (BTDC), but it's not happening late enough.
Otherwise, he's quite close to meeting the requirements.
I'm surprised by the 2.4 degrees BTDC (Before Top Dead Center) at the beginning - that's almost a 6-degree difference from mine!
The long, horizontal yellow lines represent the zero-gas phases, where there is no injection start. In these areas, the system simply continues to deliver the previous (last actual) value.
http://www.luxus-wg.de/~martin/auto_bilder/spritz.gif
Translated on 22-10-2026, 8:51.
frebert
Post21-10-2004, 10:01    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
dieselmartin wrote:
Was the box warm when you logged in??
Yes!!
dieselmartin wrote:
My 1Z wants to inject fuel
3 degrees before top dead center, but it doesn't quite manage it that late.
dieselmartin wrote:
The higher the RPM, the earlier it should inject fuel, right? Or have I been sleeping through my energy technology classes all this time???
I'm wondering about the 2.4 degrees BTDC (Before Top Dead Center) at the beginning - that's almost a 6-degree difference from mine!!!
I can go even further – up to 6 degrees before TDC (Top Dead Center).
P. S. How do I get the diagram in? }
Translated on 22-10-2026, 8:52.
Post21-10-2004, 10:41    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
S-beginning.
Why do you want to water the plants so early in the morning?
Then it just gets louder. If you adjust the basic setting in Block 4, it will advance to 17 degrees early at idle, which will be quite amusing to hear how it sputters.
Diagram:
First, create.
then put it somewhere on the internet.
and link it here via IMG.
You can see where mine is icon_smile.gif.
Translated on 22-10-2026, 8:54.
frebert
Post21-10-2004, 10:55    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Why do you want to spray warm water so early??
I didn't realize we were only talking about idle speed. But these settings are global, aren't they?
Then the idle speed is definitely affected as well, right? icon_question.gif
I would like to inject the fuel earlier because the engine becomes more responsive during acceleration, and the chip should reduce the soot emissions.
Then it just gets louder - so you adjust the basic setting in Block 4 - and it goes to 17 degrees early at idle - which is really funny, the way it then sputters.
Diagram:
First, create.
Yeah, I also saw it icon_biggrin.gif after my quick finger movement on the mouse.
Is this on the luxury hostel for "poor" ???students???[/url]
Translated on 22-10-2026, 8:56.
Post21-10-2004, 12:56    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
frebert wrote:
I would only like to inject fuel earlier because the engine becomes more agile during acceleration, and the soot emissions should be lower (due to the chip).
I would only do that if I could change the timing belt myself and had a cheap source for the parts.
Because in many turbochargers, the injection timing is already advanced, and this, combined with the higher boost pressure, increases the peak pressures.
If you push the adaptation towards early timing, I think you'll eventually find that the series ZK screws will loosen (because the head will be lifted), which means you'll have to refill water and possibly oil more frequently than diesel.
Translated on 22-10-2026, 8:58.
frebert
Post21-10-2004, 13:39    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Because in many chips, the injection start is already advanced, and together with the higher boost pressure, this increases the peak pressures.
Do I see that in the VAG values? What do the values in the VAG actually say about the injection start? Are these the values that the control unit uses for injection, or are they the actual values? Knowing this would be very important! Because a shift in the software towards "early" would then cause the actual injection to shift towards "late," because the desired injection start is far too early for the control unit. icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif
You, Ulf, have already talked about this or asked about it before. Could you summarize it?
Sure, here's the translation:
"Like that."
Adaptation Channel 1 ---> Increasing the number causes...
Adaption Channel 2 ---> Increasing the number results in (which you can easily verify yourself) a higher speed.
Adaptation Channel 3 --> Increasing the number causes...
What's important to me is the actual impact! For example, does the engine control unit actually do exactly what the data changes indicate? Or how should one approach understanding this?
"It's specifically the Channel 3, which measures the air mass, that's raising my suspicions. If I want to effectively disable the EGR, the idea is to trick the engine into thinking it's receiving very little fresh air, which should cause the EGR to close almost completely. Strangely, according to the values displayed in VAG, this happens precisely when I set very high values for the air mass = increasing the number."
Am I crazy, or am I just overthinking things?? HELP! icon_twisted.gif --> ULF
Translated on 22-10-2026, 9:01.
frebert
Post21-10-2004, 18:27    Subject: Log Data: Get the Right Insights Now Quote
Good evening.
I've now logged the correct data!! They look quite different, especially the boost pressure! icon_eek.gif icon_eek.gif
"Comments on the data are welcome!"
    Engine speed Specified MAP Actual MAP Duty cycle Injection Quantity Throttle Position
    Boost Valvle 03. Sep 0.
    /min mbar mbar % mg/R %
    1260 948.6 989.4 41 7.4 20.4
    1281 1071 1009.8 36.7 13 31.8
    1302 1060.8 1030.2 37.1 12.8 30.6
    1323 1071 1050.6 37.1 29.6 31
    1554 1948.2 1315.8 35.5 42.8 100
    2079 1989 2111.4 66.1 46.8 100
    2688 1989 1815.6 56.2 48 100
    3318 1989 2009.4 60.2 46.6 100
    3444 999.6 1815.6 59.8 37.6 100
    2856 1989 1805.4 55 47.8 100
    3129 1989 1907.4 52.6 35.6 71.8
    3318 1989 1948.2 54.6 0 72.9
    3192 989.4 999.6 59.8 0 0
    3024 979.2 948.6 59.8 0 0
    2457 948.6 948.6 57 0 0
    924 928.2 989.4 24.7 10.6 0
    861 928.2 989.4 24.7 7 0
Translated on 22-10-2026, 9:06.
Post21-10-2004, 18:31    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Do I see that in the VAG values?? What do the values in the VAG actually say about the injection start?? Are these the values that the control unit uses for injection, or are they the actual values?
The displayed values are the (approximately) real values, as long as the NBF signal is not distorted.
My air-fuel needle valve (AFN) opened the injectors at full throttle, approximately at 4000 rpm in 3rd gear, with the factory setting of around 15° advance timing.
Anything that occurs earlier increases the peak pressures.
Knowing this would be very important!! Because a shift according to the software towards an earlier timing would then cause the actual injection to shift towards a later timing, because the desired injection start is far too early for the control system.icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Here's the translation:
"It's specifically the Channel 3, which shows the air mass, that makes me suspicious. If I want to deactivate the EGR as much as possible, shouldn't I trick the engine into thinking it's getting extremely little fresh air, thus causing the EGR to close almost completely? Strangely, according to the values in VAG, this happens precisely when I set very high values for the air mass = increase the number.
You're probably confusing sensor spoofing with software modifications.
Adaptations essentially function like chip tuning, but unfortunately, the adjustment range is usually too limited (except for the VP injection start).
They look quite different, especially the turbo boost!
Hmm, the fact that it should never exceed 2000 mbar (absolutely!) suggests that this isn't typical chip tuning, but rather the standard software... unless the tuner has programmed a "piggyback tuning" solution and left the boost pressure unchanged.
Translated on 22-10-2026, 9:11.
frebert
Post21-10-2004, 19:02    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
Hi Ulf,
Thanks for your reply, but I think I'm even more confused now than I was before.
Does this mean, in plain terms, that the values you set using the adaptation feature will have a direct, one-to-one effect?
Injection start is clear.
Idle speed, also.
But what about the air mass? And the fuel injection amount in channel 1?
"Actually more air mass? Actually more fuel injection? I thought I had read in other articles that the amount of fuel injection that the software displays is only the amount that is being fed to the engine control unit."
And what is "Box Tuning"? Are you referring to an auxiliary tuning module?
No, definitely not, because the guy worked at a tuning company and supposedly messed around with the engine maps. Maybe I don't even have any tuning installed! It would be interesting to replace the engine control unit with a standard one!
Greetings.
Frebert.
Translated on 22-10-2026, 9:15.
Post21-10-2004, 19:17    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
frebert wrote:
but what about the air mass?
AGR-Fachartikel wrote:
The EGR control system uses the mass airflow sensor (MAF) voltage as a feedback signal: When the EGR valve is open, a portion of the normally aspirated fresh air is replaced by exhaust gases, which causes the MAF value to decrease accordingly. The EGR is controlled in such a way that, depending on the engine's operating conditions (boost pressure, speed, and fuel injection volume), the target value of the MAF signal, as defined by the EGR map, is reached.
If you increase the desired air mass flow rate through adaptation, the proportion of exhaust gases in the intake air will correspondingly decrease.
And what is the injection amount in channel 1??
Actually, more fuel injection volume?? I thought I had read in other articles that the fuel injection volume that the software displays is only the amount that is "fed" to the engine control unit (ECU).
In idle mode, the engine is not controlled by the amount of fuel injected, but by the engine speed.
As a result, the apparent LL injection volume decreases when quantity-based adaptation is increased.
It's just like that + In my opinion, it's difficult to explain.
And please, what is "Box Tuning"? Do you mean an auxiliary tuning module??
Yes, the effect of a box acting as a CT (Current Transformer).
Translated on 22-10-2026, 9:18.
frebert
Post21-10-2004, 19:28    Subject: AFN: Injection Timing & Turbo Pressure - Questions? Quote
When idling, the engine is not controlled by the amount of fuel injected, but by the speed (RPM).
Okay, I think I understand now, but what happens after the idle? icon_question.gif Does the adaptation then actually inject more fuel upwards, or the opposite? icon_biggrin.gif
Thank you and good night }.
Translated on 22-10-2026, 9:20.
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Injector Timing Question Diesel Engine Technology
No new posts Boost Pressure Question: Get Answers Now! Diesel Engine Technology
No new posts Boost Valve: 1Z Charging Pressure Problem? Diesel Engine Technology
No new posts VW Golf III TDI: 81kW (AFN) for Sale On-Board Diagnostics (OBD)
