A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW
Autofitti
Post11-11-2004, 20:14    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
A4 Avant 1.9 TDi 96kW, 05-2002, "Pumpe Düse" AVF engine, leaking fuel on the underside of the vehicle, specifically near the front right fuel line. Hoses and clamps are tight. The leak is located precisely at a weld seam between the pipe and the cooling fins. The plastic underbody panel is undamaged. Has anyone experienced this problem before?
Translated on 01-11-2026, 7:58.
Julian
Post12-11-2004, 16:46    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
The fuel cooler is usually located on the underside of the vehicle, near the right rear wheel, and covered by a plastic panel. Are we talking about the same component?
Autofitti
Post12-11-2004, 19:30    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
Sure, the same component was replaced today, and we received a 70% discount on the part.
Translated on 01-11-2026, 7:59.
Post12-11-2004, 19:55    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
and what was the cause...? Was it a rockfall?
Autofitti
Post13-11-2004, 12:44    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
Manufacturing defect in the weld seam on the return pipe/cooling fin body.
Post13-11-2004, 14:09    Subject: A4 Avant: Leaky Fuel Cooler - 8E, PD, 96kW Quote
Thank you very much, I wouldn't have expected that!
No new posts PD Motor Workshop: 96kW, Servo Return Hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rust on Audi 80 Avant trunk lid - rear wiper leaking Transmission, Chassis, Body & Interior
No new posts Fuel Cooler Quick Connector 3.0 TDI V6 2006 Upload
No new posts Question about the fuel cooler control valve. 1.9 TDI PD ... Diesel Engine Technology
No new posts 96kW TDI ASZ Idle Vibration Issues Diesel Engine Technology
