AGR Valve Replacement VW 1.0L with VAG-Com
Mike-T
Post10-02-2005, 21:23    Subject: AGR Valve Replacement VW 1.0L with VAG-Com Quote
Hello, is it possible that for the 1Z engine, when logging in with the ID 12233, the value 141 appears in block 03 in the series state? If so, why not 3***?
I want to reduce the AGR as much as possible.
Thank you.
Translated on 14-10-2026, 5:25.
Post10-02-2005, 21:48    Subject: AGR Valve Replacement 1Z with VAG-Com Quote
Mike-T wrote:
Hello, could it be that with the 1Z engine, when logging in with ID 12233, the value 141 appears in block 03 in the serial state? If so, why not 3***?
Older STGe devices, as far as I know, still have 3-digit adaptation values.
Translated on 14-10-2026, 5:26.
Mike-T
Post11-02-2005, 0:03    Subject: AGR Valve Replacement VW 1.0L with VAG-Com Quote
Okay, but can I also increase the value like with the newer models?
Does that actually do anything with the older 'ECUs'?
Mike-T
Post11-02-2005, 23:39    Subject: AGR Valve Replacement VW 1.0L with VAG-Com Quote
Can anyone tell me if I can set the maximum value here to influence the AGR (Exhaust Gas Recirculation) system, and if that would even make a difference with the 'older' technology? Because my intake manifold already looked like... well, you know.
And I wanted to change the hardware only if it's not possible to solve the problem with software.
Translated on 14-10-2026, 5:27.
Post12-02-2005, 9:29    Subject: AGR Valve Replacement VW 1.0L with VAG-Com Quote
Mike-T wrote:
Can anyone tell me if I can also set the value to "max" here to influence the EGR, and if that would even do anything with the "older" technology? Because my intake manifold already looked like *beep*....
Well, I don't know, I lack the experience.
And if no one else responds, you'll probably have to take on the huge task of trying it out and taking a quick look inside the microwave oven's cavity.
And I wanted to change the hardware only if it couldn't be done through the software...
Completely disabling AGR (Active Grille Roll) is likely not possible through adaptation; instead, it will probably only result in a reduction of the problem.
Translated on 14-10-2026, 5:28.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts VAG-COM: Airbag Check & Diagnosis On-Board Diagnostics (OBD)
No new posts Golf4 Variant: Adjust Comfort Module with VDS-PRO On-Board Diagnostics (OBD)
No new posts Boost Pressure Increase: Diode Method Alternatives Diesel Engine Technology
No new posts VAG TDI Tuning: Diagnostics & VW 5051 Diesel Engine Technology
