Hi Klaus,
es gibt aber von Ross-Tech bezüglich der Treiberversionen einen Hinweis:
Zitat: |
The USB drivers shipped with some previous Releases reported an incorrect version -- much higher than it should have been. When you install the new drivers that come with this version, Windows will probably complain that they are older than the ones which are already installed. You must answer "Yes" when asked if you want to replace the files anyway. Previous versions of VCDS may also complain that the new drivers are outdated. This can and should be ignored. |
Also 'ja, passt schon' klicken
PS: Du hast PN
