How high should the starting amount be set?
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post18-11-2007, 18:18    Subject: How high should the starting amount be set? Quote
I have a VW Golf (AJM engine) with 287,000 km on the clock, and it's difficult to start when it's warm. I've tried all the usual things, but nothing helps!
The starting amount is 16.5 mg, and the corresponding value is 32768!
My question is: How much can I increase the initial amount?
ehemals G4 ASZ, jetzt G4 ARL
Translated on 20-07-2026, 14:27.
Post18-11-2007, 18:35    Subject: Re: How high should the starting amount be set? Quote
3 Phasen Biber wrote:
I have an AJM here... How far can I increase the starting amount?
Depending on the software, you may be able to adjust certain settings, but the initial amount remains the same... at least that's how it seems to be with my Polo.
Just try it out, and after each change you make to the organ settings, briefly check the MWB 5 log; you should see the results there.
Translated on 20-07-2026, 14:28.
3 Phasen Biber
Post18-11-2007, 19:08    Subject: How high should the starting amount be set? Quote
I've now increased the amount to 17 mg through trial and error (value > 32786)!
The engine control unit (ECU) was installed without any problems, and the car now starts perfectly even when it's warm!
My question would have simply been, how far can I go up, if it wouldn't have achieved anything icon_question.gif.
Translated on 20-07-2026, 14:30.
Post18-11-2007, 19:14    Subject: How high should the starting amount be set? Quote
icon_question.gif.
Until it starts icon_rolleyes.gif.
Rudi
Post18-11-2007, 20:41    Subject: How high should the starting amount be set? Quote
My question would have simply been, how far could I go up, if it hadn't achieved anything icon_question.gif.
For many setpoint controllers (STGs) or channels, the minimum/maximum value is used when a value exceeds or falls below it.
Enter 40000 and see what happens.
Rudi
Translated on 20-07-2026, 14:31.
3 Phasen Biber
Post19-11-2007, 13:03    Subject: How high should the starting amount be set? Quote
@ Rainer
Okay, so if it hadn't worked at 30mg, would I have been able to increase the dose to 40mg? <= That was the question!
That is, of course, an exaggeration icon_wink.gif.
Translated on 20-07-2026, 14:32.
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM-Sollwert nach oben setzen nicht möglich Diesel Engine Technology
No new posts Brake Pedal Stuck: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Diesel or gasoline... common, outdated slang Diesel Engine Technology
No new posts VTG Closure Fixes Temporary AVB Light Issues On-Board Diagnostics (OBD)
