Diesel Engine Misfire: Why It Happens & Fixes
Horstel
Post09-07-2008, 10:20    Subject: Diesel Engine Misfire: Why It Happens & Fixes Quote
I have a 20-year-old John Deere lawn tractor with a 3-cylinder diesel engine that has always been very reliable.
"When it's cold, everything runs perfectly. But after about 10 minutes of running, it starts to jerk and sputter badly. If it sits for 5 minutes, it goes back to normal, but then after another 5 minutes, it starts doing the same thing again."
Diesel filter replaced, air filter checked. Fuel tank, etc. checked, everything is okay.
Are those the fuel injectors?
Or is it the diesel pump, or the control unit, or a sensor?
Does anyone have a suggestion?
Ralf.
Translated on 26-09-2026, 22:28.
Karma: +1100 / -0   Thank you, like it!
Post09-07-2008, 14:40    Subject: Diesel Engine Misfire: Why It Happens & Fixes Quote
"The fuel line might be slightly leaking and drawing in air. This can happen if some of the hose clamps aren't as tight as they used to be and are coming loose. We experienced something similar with a lawn tractor (with a two-cylinder diesel engine). We searched for years, and we eventually found the problem almost by chance while replacing the glow plugs."
Translated on 26-09-2026, 22:29.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Engine Heats Up Quickly - Troubleshooting Diesel Engine Technology
No new posts Servo Oil Temperature: How Hot Can It Get? Diesel Engine Technology
No new posts How hot does servo oil get? Diesel Engine Technology
No new posts Hot Brakes: Causes and Solutions Transmission, Chassis, Body & Interior
