Too much engine oil after service?
jenseden
Post03-06-2002, 14:45    Subject: Too much engine oil after service? Quote
Hello everyone,
hatte meinen Passat jetzt in der Inspektion (43TKM). It was the...
obligatorische Ölwechsel in der VAG-Werkstatt durchgeführt. Htoday
I checked the oil level with the dipstick: it was approximately 2 cm above the.
Maximum marking.
Is this harmful to the engine? Should I report this?
Thank you very much for your answers!
Translated on 15-10-2026, 4:52.
Cheffe
Post03-06-2002, 15:24    Subject: Too much engine oil after service? Quote
Okay, so if you've measured the oil level correctly and it's really that far above the "Max" mark, it could definitely lead to damage (e.g., to the catalytic converter).
Translated on 15-10-2026, 4:53.
Ernst S.
Post03-06-2002, 18:40    Subject: LMM: What is it? Definition & Explanation Quote
'In my Passat (with the AHU engine), they also overfilled it by about 1.5 cm. About 300 km later, the mass airflow sensor failed. I even noticed a decrease in performance just 30 km after the oil change.'
On my Passat, the crankcase ventilation hose connects to the intake hose about 10 cm away from the mass airflow sensor (MAF). I believe that the crankshaft is causing excessive oil to foam, and that this oil, which the ventilation system (likely overwhelmed by the amount of oil) can't fully separate, then reaches the MAF sensor.
Even though the LMM (likely referring to a lambda sensor) doesn't have a long lifespan anyway, the fact that it failed after such a short distance following the oil overfill strongly suggests that the overfill was the cause.
That's why the mechanic who changed the oil was also allowed to sponsor me a new MAF sensor icon_smile.gif.
And a year later, my cat also broke down (at 65,000 km... which is a bit early, isn't it?).
Okay, so get the oil out immediately and contact the workshop right away to make sure they are responsible if the catalytic converter breaks down prematurely.
In my engine compartment, there are 2 warnings that the catalytic converter will fail due to oil overfilling... so, in reality, the workshop's license should be revoked immediately. icon_evil.gif (and it's 2cm overfilled... that's almost 2 liters too much).
Translated on 15-10-2026, 4:55.
Ernst S.
Post03-06-2002, 19:08    Subject: SEO-Optimized: "Best German Translation Services Online" Quote
Regarding the mass airflow sensor (MAF): The oil doesn't necessarily have to flow directly to the MAF to damage it. Even an oil mist is sufficient. And the oil mist can even travel against the airflow direction towards the MAF. However, in the case of the AFN engine, the path from the crankcase ventilation system to the MAF is quite long (I believe/hope so for you).
And regarding the catalytic converter: it doesn't necessarily need to be replaced immediately. The large amount of oil that oxidizes inside it causes it to overheat and become damaged. It might not completely fail until after a few thousand kilometers. However, without the excess oil, it would likely last much longer.
Translated on 15-10-2026, 4:57.
No new posts Debris and fragments in engine oil bind General Tips
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ACEA B3-98 Engine Oil for Direct Injection Engines Diesel Engine Technology
No new posts Clutch Slippage After Brake Pad Replacement Diesel Engine Technology
No new posts Inspection: Your Complete Checklist & Guide Transmission, Chassis, Body & Interior
No new posts 60,000 Mile Service at ATU? Diesel Engine Technology
