VCDS 1507: Missing ASAM Data?
Post30-08-2015, 18:54    Subject: VCDS 1507: Missing ASAM Data? Quote
During the diagnostic scan of my Polo, I encountered unusual error messages indicating missing ROD or ASAM data – see the attached files for addresses 03, 15, and 55.
Interestingly, the ASAM dataset that is being criticized is located just a few lines above it.
I'm writing this because VCDS is asking me to send the Autoscan data to RossTech or the distributor.
BTW: What do these ROD and ASAM data actually mean?
Log-WVWZZZ6RZEYxxxxxx-3600km.txt
 File name:  Log-WVWZZZ6RZEYxxxxxx-3600km.txt
 File size:  7.2 KB
 Downloaded:  1433 times
Translated on 02-09-2026, 2:57.
Post30-08-2015, 19:11    Subject: VCDS 1507: Missing ASAM Data? Quote
Hello Ulf,
This is roughly equivalent to the label files, i.e., descriptions of control units, descriptions of measured values, etc.
Translated on 02-09-2026, 2:58.
Post03-09-2015, 13:24    Subject: VCDS 1507: Missing ASAM Data? Quote
Version 15.7.0.0 should generally be used with caution (see https://community.dieselschrauber.org/en/viewtopic.php?p=224853#224853):
Can I install VCDS DRV 14.10.0.0 alongside version 15.7.0.0 on my "Logtop" so that both versions are functional and don't interfere with each other?
If so, what should I be aware of?
Translated on 02-09-2026, 2:59.
Post03-09-2015, 13:39    Subject: VCDS 1507: Missing ASAM Data? Quote
Hello Ulf,
Yes, that's no problem.
Post03-09-2015, 16:39    Subject: VCDS 1507: Missing ASAM Data? Quote
During the installation of updates, you sometimes get prompts like "Uninstall old drivers?"
Should I then choose "do not uninstall"? Or is that option only presented when the update is installed in the same directory as the previous version?
Translated on 02-09-2026, 3:00.
Post03-09-2015, 17:21    Subject: VCDS 1507: Missing ASAM Data? Quote
You can leave the drivers as they are.
Post04-09-2015, 13:45    Subject: VCDS 1507: Missing ASAM Data? Quote
Hi Ulf,
There is an update regarding this in the customer account.
https://shop.dieselschrauber.de/account.php
Post04-09-2015, 15:47    Subject: VCDS 1507: Missing ASAM Data? Quote
"Thank you!"
With this, you will no longer receive error messages on the Polo regarding missing files, and the basic LWR (Low Voltage Regulator) setting will also work icon_smile.gif.
Translated on 02-09-2026, 3:01.
Xbuman
Post05-06-2016, 19:05    Subject: VCDS 1507: Missing ASAM Data? Quote
Unfortunately, I'm experiencing the same problem, and I don't have access to any previous versions to test whether they work better.
Log.txt
 File name:  Log.txt
 File size:  8.4 KB
 Downloaded:  528 times
Post05-06-2016, 19:57    Subject: VCDS 1507: Missing ASAM Data? Quote
Hi Xbuman,
Please send a full vehicle scan to Ross-Tech in cases like this.
Translated on 02-09-2026, 3:02.
Xbuman
Post08-06-2016, 15:57    Subject: Quick Feedback: Get Fast Responses Now! Quote
My mechanic couldn't read the error code with the new diagnostic tool initially, but then he was able to read it with the older tool. The oxygen sensor was defective.
"The reason was that the car is old, but the engine is new," according to the friendly person.
No new posts Audi A3 8L Dashboard - No Display Segments Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS - Some options are missing under Basic Settings On-Board Diagnostics (OBD)
No new posts VCDS ROD Data Missing Skoda Superb 3 On-Board Diagnostics (OBD)
No new posts AKF Failure: Cylinder Missing After BAB Run. Diesel Engine Technology
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
