Sealing: How to Seal & Prevent Leaks | Posts 16+
Go to page: Previous  1, 2
avogt_de
Post16-05-2017, 7:19    Subject: Sealing: How to Seal & Prevent Leaks Quote
How can I seal this flexible joint? It consists of two pipes that are pushed together with accordion bellows and have a steel mesh covering them. It's movable (presumably it's supposed to be), and there's about 1-2 cm of play.
The steel mesh is slightly damaged at the top. Would it be enough to apply sealant around it and possibly wrap it with aluminum foil or something similar?
You would have to weld the pipes together, right?
It's a Volkswagen Passat TDI 1.9L Variant (estate/wagon) manufactured in 2002.
Thank you, Andy.
Translated on 16-08-2026, 6:09.
Post16-05-2017, 8:15    Subject: Sealing: How to Seal & Prevent Leaks Quote
Don't try to seal it (it won't last anyway), replace it!
Translated on 16-08-2026, 6:11.
avogt_de
Post16-05-2017, 11:15    Subject: Replace Flex Pipe: Cost & DIY Guide Quote
Okay, so how can I do this? It seems like it comes from the turbocharger and then continues on. Where it's connected with the steel mesh, there's probably a connector installed.
Is this part available for purchase online? Does anyone have a part number?
Thank you.
avogt_de
Post18-05-2017, 15:09    Subject: Driving Again: Get Back on the Road! Quote
Okay, so the flexible pipe will stay in place for now and will be replaced later if it actually leaks.
The hose connecting the turbo to the intercooler was replaced, but it immediately came loose on the first drive – apparently, the spring/clamp wasn't properly secured.
Okay, let's hope it stays that way...
Thank you!
Translated on 16-08-2026, 6:12.
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat 2.5 TDI: Power Loss & Noise Issues Diesel Engine Technology
No new posts TDI Passat: Ticking Noise - Common Problem? Diesel Engine Technology
No new posts Passat 3C: Grinding Noise When Turning & Accelerating Transmission, Chassis, Body & Interior
No new posts Passat 3C: Transmission or Dual Mass Flywheel? Diesel Engine Technology
