Gear problem when shifting into reverse
vag-driver
Post26-06-2017, 7:23    Subject: Gear problem when shifting into reverse Quote
It's about my wife's Polo 6N1 with 312,000 kilometers. The gearbox code is DKE, which means it has a cable-operated gear shift.
The problem only occurs after driving for a certain distance, i.e., when the transmission is warm. Reverse gear can only be engaged with a grinding noise, as if the clutch isn't fully disengaging.
Otherwise, the gears can be shifted without any problems.
What could be the cause, or what can be tried to rule out certain possibilities? Or is a transmission defect imminent?
My ideas are to replace the clutch cable and change the gearbox oil. At approximately 200,000 kilometers, I replaced the clutch including the release bearing.
Andreas
Translated on 10-07-2026, 10:55.
Post26-06-2017, 9:26    Subject: Gear problem when shifting into reverse Quote
Could the clutch be disengaging too late because the clutch cable has stretched or become "elastic" (due to broken cable strands)? Is there possibly a bearing (needle bearing) for centering the transmission input shaft on the engine side that could be defective?
Translated on 10-07-2026, 10:57.
vag-driver
Post26-06-2017, 9:55    Subject: Gear problem when shifting into reverse Quote
dieselschrauber wrote:
trennt die Kupplung evtl. zu spät, weil sich das Kupplungsseil gelängt hat bzw. "elastisch" (gerissene Seilfasern) geworden ist?
Then my expectation is that all the gears are difficult to shift. However, it's only the "R" (reverse) gear. icon_rolleyes.gif
Andreas
dieselschrauber likes this.
Post26-06-2017, 10:21    Subject: Gear problem when shifting into reverse Quote
vag-driver wrote:
Then my expectation is that all the gears are difficult to shift. However, it's only the "R". icon_rolleyes.gif
The forward gears are synchronized, but the reverse gear is not in these transmissions. icon_wink.gif
Translated on 10-07-2026, 10:58.
vag-driver
Post26-06-2017, 12:01    Subject: Gear problem when shifting into reverse Quote
Am I understanding correctly that the recommendation is to replace the clutch cable?
Andreas
Translated on 10-07-2026, 10:59.
No new posts Reverse Gear Not Working: Doku Sharan Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Side Mirror Adjustment Not Working? Transmission, Chassis, Body & Interior
No new posts Gear Issues: 1st & Reverse Gear Problems Transmission, Chassis, Body & Interior
No new posts Could not engage gear Diesel Engine Technology
No new posts Gear problem ??? Diesel Engine Technology
