Activate AHK on Audi A4 B8
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
monsieurincroyable
Post05-07-2017, 8:23    Subject: Activate AHK on Audi A4 B8 Quote
An aftermarket trailer hitch was installed on my vehicle (Audi A4 B8 2.7TDI, year 2011). Now, the coding of the control units has been attempted, but it was successful for all units except for SG3, the braking electronics module. The byte that needs to be set is Byte 1, Bit 7.
"Trailer detection and stabilization."
There, the following message appears:
"Encoding not accepted, error 33: access permission required."
What should I do?
 "Codierung nicht akzeptiert, Fehler 33 Zugriffsberechtigung benötigt"
 File size:  78.46 KB
 Viewed:  7869 times
 File size:  78.9 KB
 Viewed:  3927 times
 File size:  78.46 KB
 Viewed:  2755 times
Autoscan.txt
 Autoscan
Autoscan
 File name:  Autoscan.txt
 File size:  18.72 KB
 Downloaded:  1532 times
Translated on 22-09-2026, 14:29.
Post05-07-2017, 19:10    Subject: Activate AHK on Audi A4 B8 Quote
According to Ross-Tech, the corresponding login code/security access is already displayed in the tooltip when you hover the mouse cursor over the input field for the login code/security access in the ABS/ESP module.
Please review this.
Translated on 22-09-2026, 14:30.
Post05-07-2017, 22:06    Subject: Activate AHK on Audi A4 B8 Quote
The AHK stabilization system in ABS/ESP is usually not reprogrammable and may not even be available.
Reason:
The registration document states that the stabilization system for the trailer hitch is only available if the trailer hitch is factory-installed.
I've had some vehicles before where that feature couldn't be coded.
The PQ35, on the other hand, automatically recognized it once the gateway was correctly encoded. It's possible that the manufacturers are now consistently blocking this feature through component protection.
Translated on 22-09-2026, 14:31.
Benni
Post14-07-2017, 17:53    Subject: Activate AHK on Audi A4 B8 Quote
I was able to code it on my A5, model year 2015.
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock TV on Audi A8: Easy Guide Transmission, Chassis, Body & Interior
No new posts MMI Plus: Unlock Audi A6 (4G) Hidden Menu Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A6: Unlock Immobilizer with Code via OBC On-Board Diagnostics (OBD)
No new posts PDC Trailer Coupling: Enable/Unlock Feature On-Board Diagnostics (OBD)
