schimme Blaumann
13-07-2008, 20:41 Subject: Needle Valve Check: Disassembled Condition |
Hello everyone!
I would like to know if it is possible to test a new hydraulic generator (NHG) even when it is already assembled. I am familiar with the "tapping test" that is useful when the generator is installed, but it doesn't help much when the unit is on the workbench.
glimmer
Translated on 04-09-2026, 11:05.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
13-07-2008, 21:57 Subject: Needle Valve Check: Disassembled Condition |
It's impossible to reliably test the NHG unless you drive around in a car. The device might work perfectly for an hour, and then suddenly stop functioning for a few seconds.
Checking the engine control unit's fault memory is the most effective way to diagnose the problem.
Edit: Technical article about the needle advance mechanism, https://community.dieselschrauber.org/en/viewtopic.php?t=26339
Translated on 04-09-2026, 11:06.
Profile PM WWW Garage |
schimme Blaumann
14-07-2008, 15:58 Subject: Needle Valve Check: Disassembled Condition |
That's a shame... I guess I'll have to figure out the installation and testing myself. Thanks for the reply!
Translated on 04-09-2026, 11:07.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1141 Karma: +36 / -0 Location: Wien 2001 Audi A2  Premium Support
15-07-2008, 9:22 Subject: Needle Valve Check: Disassembled Condition |
schimme wrote: | | That's a shame... then I'll probably have to find a way to install it and try it out. Thanks for the answer! |
How about connecting the NHG to the cable, turning on the ignition, and logging into the engine control unit?
This should be sufficient as a preliminary test.
Profile PM Garage |
wolfi_b Profi-Schrauber
15-07-2008, 14:18 Subject: Needle Valve Check: Disassembled Condition |
However, a resistance test can also be performed in a simpler way  .
"Furthermore, I believe that NHGs are more likely to fail due to mechanical problems than electrical ones."
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 04-09-2026, 11:08.
15-07-2008, 14:35 Subject: Needle Valve Check: Disassembled Condition |
I performed a resistance test on my faulty NHG (fused disconnect switch) – the error code indicated a short circuit after the positive terminal – but I couldn't detect any difference.
What does a mechanical failure look like in a new car?
Translated on 04-09-2026, 11:09.
Profile PM Garage |
kossmann Blaumann
2016 Audi Q3 Premium Support
16-07-2008, 10:40 Subject: Needle Valve Check: Disassembled Condition |
Something might be stuck or broken... This is roughly what the inside looks like.
...or it could simply be an exposed (uninsulated) section of the cable.
| Description: |
| File size: |
45.05 KB |
| Viewed: |
19057 times |
Profile PM Email Garage |
A6 Andreas Blaumann
23-07-2008, 7:40 Subject: Needle Valve Check: Disassembled Condition |
I have a question about that too.
Does the NTC resistor provide a resistance signal, or is it positive or negative?
I'm asking because I just installed a new one myself.
The Aber of the new generation had a different plug adapter, costing 80 euros.
I quickly modified the plug.
Now, I've mixed up the cable connections on my old device, and I'm not sure which cable goes where.
Is there a way to measure that?
The connector indicates +/- for the cables, but unfortunately, both cables are white with no markings.
I would like to keep it as a spare part, as the injector nozzle was still okay after the pressure test.
Oh, I swapped them out because two of the nozzles were damaged.
Translated on 04-09-2026, 11:10.
marson
16-01-2018, 22:38 Subject: Needle Valve Check: Disassembled Condition |
Okay, I'll dig that thing out. I unfortunately have the NHG without the connector housing, and I really don't want to connect it with the wrong polarity.
Translated on 04-09-2026, 11:12.
Herbert Profi-Schrauber
17-01-2018, 10:36 Subject: Needle Valve Check: Disassembled Condition |
How will you distinguish between the two wires?
Both of them are, in fact, the leads of the same coil.
marson
17-01-2018, 10:49 Subject: Needle Valve Check: Disassembled Condition |
Since it's white, there's nothing visible. Therefore, it seems like it doesn't matter.
17-01-2018, 11:41 Subject: Needle Valve Check: Disassembled Condition |
marson wrote: | | Since they are white, there is absolutely none. | Therefore, it seems that it doesn't matter? }
It shouldn't really matter, but the effort required for a test drive to try it out is manageable, as there are only two possible options.
Testing without a car requires an oscilloscope, a power supply, and a clamping device, which probably wouldn't be worth the effort.
Translated on 04-09-2026, 11:13.
