AGR Seat for VW Sharan 7N
vag-driver
Post30-04-2018, 17:12    Subject: AGR Seat for VW Sharan 7N Quote
Just now, the check engine light came on. I then read the OBD interface.
Address 01: Engine Control Module (J623-CFGB) Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 F, HW: 03L 907 309 Q.
Component: R4 2.0L EDC H24 0257
Revision: 44H24--- Serial number:
Encoding: 0019001A043401080000
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018F 003003
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 2D573FB17C5A872CBA-8078
"One error found:"
4891 - Exhaust gas recirculation valve (N18)
P0403 00 [232] - Malfunction.
Warning light ON - Intermittent - Confirmed - Checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 3
Mileage: 134,617 km
Date: 2018.04.30
Time: 16:08:32
Motor speed: 1270.00 rpm.
Normalized load value: 23.1%
Vehicle speed: 18 km/h
Coolant temperature: 43 °C.
Intake air temperature: 20 °C
Atmospheric pressure: 980 millibars.
Voltage at terminal 30: 13.080 V.
Lost learning counter via OBD: 40.
Air mass: Actual value (mg/stroke): 512.4 mg/stroke.
Exhaust gas recirculation valve: Control signal: 15.00%.
Exhaust gas recirculation valve: Current value: 96.51%.
Exhaust gas recirculation valve: Offset closed: 5.71%.
High-pressure exhaust gas recirculation (EGR) valve: Status bits 0-7: 0.
Exhaust Gas Recirculation (EGR) High-Pressure: Status Bits 0-7: 55.
High-pressure exhaust gas recirculation (EGR) valve: Status bits 0-7: 7.
Exhaust Gas Recirculation (EGR) High-Pressure: Status Bits 0-7: 3
Exhaust Gas Recirculation (EGR) Valve - High Pressure: Actual Value (Raw Voltage): 933.2 mV.
Readiness: 1 1 0 0 0
How can I clean them? Or would it be better to just install new ones? As far as I know, the installation space in the Sharan 7N is quite limited.
Andreas
Translated on 29-09-2026, 21:34.
vag-driver
Post01-05-2018, 9:23    Subject: AGR Seat for VW Sharan 7N Quote
The video becomes interesting starting from the 12th minute. The real reason for the VW AGR issue?
Andreas
Translated on 29-09-2026, 21:39.
vag-driver
Post12-05-2018, 14:56    Subject: AGR Seat for VW Sharan 7N Quote
Yesterday, the software update regarding the "Dieselgate" issue was supposed to be installed. Before that, I had cleared the error codes because the check engine light was on.
1. I was concerned that the update might not be installable due to error entries related to emissions.
"Did I expect that the AGR (Agricultural Guarantee Fund) would experience more problems after the update?"
Result:
After 3 hours, I received a friendly call informing me that everything was completed and in order.
2. So far, I've driven about 70 km, and I haven't had any error messages since the update.
"Now I'm wondering what else VW did besides the update and refilling the AdBlue tank, without mentioning it. Because for the past two weeks, I've had persistent DPF (Diesel Particulate Filter) errors in the system, and for the past few days, the check engine light has been coming on after about 20 km of driving."
Andreas
Translated on 29-09-2026, 21:40.
Dieseloptimist
Post12-05-2018, 16:59    Subject: AGR Seat for VW Sharan 7N Quote
They've obviously installed a new or at least cleaned EGR valve, which will become much dirtier again after the software update, as even more exhaust gases will be routed through it. If you don't clean it yourself from time to time, it can become a very expensive problem.
I cleaned my EGR valve the day before yesterday; it wasn't a problem to take it apart, but it's a really dirty job. Besides that, the intake manifold doesn't look much better, but it hasn't caused any problems so far. However, cleaning that will be a task that dwarfs everything I've done before.
Translated on 29-09-2026, 21:42.
vag-driver
Post12-05-2018, 18:29    Subject: AGR Seat for VW Sharan 7N Quote
Dieseloptimist wrote:
They obviously installed a new or at least a cleaned EGR valve...
Certainly not in 3 hours. Why would they do that?
How/with what did you clean your EGR valve? What vehicle?
Andreas
Translated on 29-09-2026, 21:43.
Post12-05-2018, 18:33    Subject: AGR Seat for VW Sharan 7N Quote
Definitely not in 3 hours.
Depending on the age of the vehicle, to prevent stress? Replacing the AGR valve takes about 5 minutes on the BRE engine; of course, I don't know how it's installed on your engine in the Sharan. icon_cool.gif
Translated on 29-09-2026, 21:44.
vag-driver
Post12-05-2018, 18:47    Subject: AGR Seat for VW Sharan 7N Quote
"I've heard everything from 3 to 10 hours for this job. The AGR valve is located on the engine block, below the turbo and DPF, near the fuel injection system. It involves removing the DPF and all the hoses that obstruct access to the AGR valve. This is definitely not a quick or easy job."
Andreas
vag-driver
Post25-05-2018, 9:01    Subject: AGR Seat for VW Sharan 7N Quote
Since the update, I've driven approximately 450 km. The error persists, as a logical consequence. The day before yesterday, the check engine light was on again. Yesterday, it turned off on its own.
The engine has no power loss and has not yet entered emergency mode.
How can this behavior be explained without any external intervention?
Andreas
Translated on 29-09-2026, 21:45.
Post25-05-2018, 16:35    Subject: AGR Seat for VW Sharan 7N Quote
Speculation: Was it knitted with a needle that was too hot, and was it tested too little? icon_rolleyes.gif
Translated on 29-09-2026, 21:46.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M8: Reduced Steering Assist Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan Brake Pad Wear Sensor On-Board Diagnostics (OBD)
No new posts Brakes T4 / Sharan Transmission, Chassis, Body & Interior
No new posts Sharan 7N1 Brake Parts & Accessories Transmission, Chassis, Body & Interior
No new posts Tempomat Sharan On-Board Diagnostics (OBD)
