More Problems After Major Upgrade.
S6marc
Post01-06-2018, 20:58    Subject: More Problems After Major Upgrade. Quote
Hello everyone,
After replacing the turbocharger due to a lack of performance, and without any errors in the memory, the problem has now become even worse.
The engine only runs up to about 1500 RPM and then makes a rattling noise, like a pump or turbocharger.
The VTG lever doesn't move when I accelerate (even when fully engaged).
In the MWB11 actuator diagnosis, it fully opens and closes without getting stuck.
If I disconnect the vacuum hose from the VTG valve.
He turns it up smoothly and quietly icon_question.gif.
Thank you in advance.
Translated on 02-10-2026, 15:30.
S6marc
Post01-06-2018, 21:01    Subject: VTG Regulation: Explained and Simplified Quote
Could it be that if the VTG (variable turbine geometry) doesn't activate in time, it could restrict its own exhaust flow?
Translated on 02-10-2026, 15:31.
S6marc
Post01-06-2018, 21:10    Subject: More Problems After Major Upgrade. Quote
Okay, regarding the vehicle, it's a Caddy 2K, 1.9 TDI, engine code BLS, with 77 kW.
S6marc
Post02-06-2018, 14:44    Subject: Software Update: Latest Version & Features Quote
So kurzes Update. Nochmal alles rund um die Unterdrucksteuerung getestet alles i. O.
MWB 011: Re-tested the basic settings and paid attention to the pressure behavior. Delta pressure: 370 mbar icon_eek.gif.
I think the VTG setting on the "reconditioned" loader is not set correctly icon_evil.gif.
It's difficult to adjust because you can hardly access it when it's installed.
I will remove the charger again and compare its settings with my old one.
Translated on 02-10-2026, 15:32.
Post03-06-2018, 16:50    Subject: More Problems After Major Upgrade. Quote
Autoscan, customer data?
Translated on 02-10-2026, 15:33.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Quality Sensor Replacement: Golf 7 Error Persists Electrical Systems, Vehicle Electronics, Multimedia
No new posts Nach AGR Ventil Tausch Probleme Diesel Engine Technology
No new posts G4 Performance Issues: AGR Problems Persist. On-Board Diagnostics (OBD)
No new posts Car Door Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
