DSG Grundkonfiguration Audi DL501 vs. VW DQ500
Tobias79
Post02-04-2019, 9:27    Subject: DSG Grundkonfiguration Audi DL501 vs. VW DQ500 Quote
Hello!
Is the procedure for the 0BT 7-speed DSG DQ500 in the T5.2 identical to that from the article (/viewtopic.php?t=27262&highlight=dsg+grundeingabe) for the 0AM on the transverse engine?
Thank you.
Tobias
Post01-05-2019, 19:41    Subject: DSG Grundkonfiguration Audi DL501 vs. VW DQ500 Quote
Hi, please perform an auto-scan. Then I will use it to inquire with the manufacturer. Without the VAG part number, nothing works!
Best regards, Rainer Kaufmann
Tobias79
Post07-05-2019, 8:57    Subject: DSG Grundkonfiguration Audi DL501 vs. VW DQ500 Quote
attached is the car scan. The DQ500 has HW: 0BH and SW: 0BT
Thank you, Tobias.
Autoscan-WV2ZZZ7HZCH119830-158010km.txt
 Autoscan T5.2
Autoscan T5.2
 File name:  Autoscan-WV2ZZZ7HZCH119830-158010km.txt
 File size:  14.63 KB
 Downloaded:  576 times
Post20-05-2019, 18:18    Subject: DSG Grundkonfiguration Audi DL501 vs. VW DQ500 Quote
Ross-Tech Support wrote:
Thank you for sending us your question and also thank you for including the vehicle's Auto-Scan. The Basic Settings procedure does not appear to be the same for the [0AM] and the [0BT] 7-Speed Direct Shift Gearbox (DSG) transmissions. As far as I can tell, the [0AM] are non-UDS controllers, and the [0BT] is using a UDS controller.
See the wiki page for the [0AM] Basic Settings.
http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM)
If you wish, the following procedure is for UDS Controllers and is NOT fully tested, and should be used at your own risk.
[0BT - Basic Settings Procedure]
- Procedure for adapting UDS Controllers to a standstill
Prerequisites:
- Transmission fluid temperature between 30°C - 100°C
- Do NOT continue if the temp is out of specs! -
- Advanced Measuring Values = [Control Module temperature]
- Selector lever in [P]
- Engine idle speed, do not press accelerator pedal
- Parking brake and foot brake were applied throughout the entire procedure
- Note: Not all transmission controllers support this function
- Make sure all the Prerequisites are followed, important! - The brake pedal must be depressed throughout the entire procedure.
[Select]
[02 - Transmission]
[Basic Settings - UDS]
- Select [Basic settings of transmission]
Next click [Show Measuring Data] and select:
- [Engine speed]
- [Main status of abort code basic setting]
- [Basic settings status]
- [Status of basic setting data for clutch]
- [Status of basic setting data; gear selector]
- [Basic setting for abort code]
Then press [Go!]
- During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal.
Basic settings may not complete successfully if:
- The fluid temperature gets too hot.
- Brake released
Once completed, there should be an indication of this in the [Status of Basic Settings].
Then click - [Done, Go Back] and Check for fault codes.
Thank you for sending your question and also for including the vehicle scan. The procedure for the basic settings appears to differ for the 7-speed manual transmission (DSG) models [0AM] and [0BT].
As far as I can see, the [0AM] non-USD controllers and the [0BT] use a UDS controller.
On the Wiki page, you can find the basic settings for [0AM].
If you wish, we have the following procedure for UDS controllers, but it is NOT fully tested and can be used at your own risk.
[0BT - Basic Setup Procedure]
- Standby adaptation procedures for UDS controllers
Requirements:
- Transmission oil temperature between 30°C - 100°C
- Do NOT continue if the temperature is outside the specifications! -
- Expanded Measurement Values = [Temperature of the control module]
- Gear lever in [P].
- Engine idle speed, with the accelerator pedal not depressed.
- Parking brake and foot brake must be applied throughout the entire process.
- Note: Not all gear shift controls support this function.
- Make sure all requirements are met, very important! - The brake pedal must be pressed throughout the entire process.
[Select]
(02 - Transmission)
- Select [Basic Transfer Settings].
Click on [Show Measurement Data] and select:
- [Engine Speed]
- [Main status for the abort code]
- [Default Settings Status]
- [Status of base settings for the clutch]
- Status of base settings; Gear selector]
- [Default Status of Abort Code]
Then press [Start!].
- During the initial setup, you may hear loud gear noises from the transmission, which is normal.
The initial settings may not be successfully completed if:
- The liquid temperature is getting too high.
- Brake is released
Upon completion, this should be displayed in the [Status der Grundeinstellungen] section.
Click then on -[Finish, Back] and look for error codes.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts SQ100 Transmission: Troubleshooting Basic Settings Transmission, Chassis, Body & Interior
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts AAT Default Settings: Guide & Optimization Diesel Engine Technology
