vw Polo 6C Front Assist error after trailer hitch installation
r.bierstedt
2016 Volkswagen Golf
Post23-06-2020, 11:47    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
Hello, I'm new here, as you can probably tell. I recently got VCDS and unfortunately haven't been able to find what I'm looking for through the search function.
Two weeks ago, a Polo 6C was given to me by someone from the extended family, after which an unknown person had installed a tow hitch.
Looking back, I think I coded the AHK in the same way that I'm reading about now on "dieselschrauber."
Perhaps someone will immediately spot what's wrong, or has experienced a similar issue with a similarly young vehicle.
AHK Anleitung.pdf
 Anleitung zur AHK
Anleitung zur AHK
 File name:  AHK Anleitung.pdf
 File size:  40.2 MB
 Downloaded:  652 times
fehler.pdf
 Fehlertext
Fehlertext
 File name:  fehler.pdf
 File size:  107 KB
 Downloaded:  577 times
verbau.pdf
 Steuergeräteverbauliste
 File name:  verbau.pdf
 File size:  103.77 KB
 Downloaded:  575 times
Translated on 21-07-2026, 16:01.
vag-driver
BackSledge likes this.
Post23-06-2020, 13:39    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
Do you have a way to access the original coding information? Because I didn't find any instructions on how to code the tow hitch for initial setup.
Based on the error message, it appears that the ACC (Adaptive Cruise Control) is not working or is not functioning correctly.
Andreas
Translated on 21-07-2026, 16:02.
r.bierstedt
Post23-06-2020, 13:46    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
"Unfortunately, I don't know the person and I also don't know if or what he recorded or saved. It was said that he installed an AHK (trailer hitch) and that it was programmed accordingly, according to the customer. But now her FrontAssist is no longer working, and he dismissed it by saying she should take it to VW. Since she's family, she wanted to ask me first. I could certainly send her to VW, but of course I'm interested in understanding the problem."
Translated on 21-07-2026, 16:03.
Herbert likes this.
Post23-06-2020, 22:00    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
Okay, I'm not following this. In your first post, you wrote that someone mechanically installed the trailer hitch and that you coded everything as described. Was anything already coded at that point? Did you see any errors or use a car scan tool at that time? What exactly else did you do?
My tip.
It doesn't matter to any of us whose brother-in-law's colleague owns the mill. No embellishments, just facts. That would also align better with the data...
Okay, this is all getting a bit vague. If someone has previously coded data on their computer, you need to retrieve that data and properly store it in VCDS. Then, verify the coding and correct any errors.
Right now, everything is just a mess and nothing seems to work properly.
Translated on 21-07-2026, 16:04.
vag-driver
r.bierstedt likes this.
Post24-06-2020, 6:21    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
Without knowing the original encodings and without documentation specifying what needs to be encoded, the path to Volkswagen will remain unavoidable.
Andreas
Translated on 21-07-2026, 16:05.
r.bierstedt
Post24-06-2020, 7:07    Subject: I thought so Quote
Yes, that's a shame. I suspected that I wouldn't be able to proceed without the previous data from that person. Unfortunately, I don't know what he did. So, I suppose I'll have to take them to VW. Thank you for your efforts, though.
Translated on 21-07-2026, 16:06.
vag-driver
Herbert likes this.
Post24-06-2020, 10:24    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
Why don't you take the car back to the installer of the trailer hitch? They should either properly code it or at least reset the original coding.
Andreas
r.bierstedt
Post24-06-2020, 10:35    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
"He said he couldn't do it and that she should take it to Volkswagen. He tried, but it doesn't work 'the way he always does it.'"
Translated on 21-07-2026, 16:07.
dieselschrauber likes this.
Post24-06-2020, 18:28    Subject: vw Polo 6C Front Assist error after trailer hitch installation Quote
So, the person who wrote the code is known. They should provide their log file; it's quite simple, as it contains everything about what changes were made, when, and by whom.
No new posts Airbag Error 1317: Polo MJ 2001 Diagnostic Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Automatic transmission error. Gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA errors after AHK installation, Roomster 2010 On-Board Diagnostics (OBD)
No new posts RNS2 Installation: Control Unit Errors On-Board Diagnostics (OBD)
No new posts GRA Supplemental Restraint System (SRS) Installation Erro... On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
