DPF Not Regenerating: Causes & Fixes | Posts 16+
Go to page: Previous  1, 2
Hsk1816
Post31-01-2023, 7:21    Subject: DPF Not Regenerating: Causes & Fixes Quote
Good day everyone,
I also have a question regarding DPF regeneration. I own a VW Touran with the 1.9 TDI BLS engine, and the DPF was recently replaced because it had 70 grams of ash and was completely full. A brand new one was installed, and the ash counter was reset. Since then, it hasn't regenerated. The DPF light came on again, indicating that regeneration is needed, and the load was at 47%, but nothing happened. Even forced regeneration doesn't work because the temperatures don't reach above 600 degrees.
I've already checked the other forums regarding the pressure sensor, but it seems to be working fine. The idle speed is 12 (with an offset of 0), and all the temperatures are displayed and seem reasonable. (One catalytic converter was replaced because it broke during removal). The oxygen sensor has been replaced. I've also checked the EGR valve, and everything seemed okay there. The mass airflow sensor is also fine. And when driving, everything seems normal.
I'm quite at a loss now as to why it doesn't want to start the regeneration process.
I was wondering what the lambda value is at idle for a diesel engine. Unfortunately, I haven't been able to find any information on that either.
Translated on 30-07-2026, 12:55.
dieselschrauber likes this.
Post31-01-2023, 10:11    Subject: DPF Not Regenerating: Causes & Fixes Quote
Autoscan.
Translated on 30-07-2026, 12:56.
Hsk1816
Post31-01-2023, 12:40    Subject: DPF Replacement: Volkswagen Touran Repair Quote
Okay, I will create it this afternoon.
Translated on 30-07-2026, 12:57.
Hsk1816
Post31-01-2023, 20:57    Subject: DPF Replacement: VW Touran Repair Quote
Please provide the scan so I can translate it for you.
Vehicle type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 72 77
Vehicle Identification Number (VIN): WVGZZZ1TZ6W187859. Mileage: 228,770 km.
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08 - Climate Control/Heating Unit - Status: Error 0010.
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
Auxiliary heating system (or parking heater) -- Status: OK 0000.
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: Error 0010.
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module
Label file: DRV\03G-906-021-BLS.clb
Part number SW: 03G 906 021 HK, HW: 03G 906 021 HK.
Part: R4 1.9L EDC G000SG 0016
Revision: --H02--- Serial number: VWZ7Z0F4064327
Encoding: 0000072
Operating number: WSC 65536 642 00000
VCID: 6FEA4B937E8EAB46B4-803A
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AA, Hardware: 1K0 907 379 AA.
Component: ESP FRONT MK60 0102
Revision: 00H13001
Encoding: 0021190
Operating number: WSC 01324 785 00200
VCID: 71EE4DEB68BABDB6A2-8024
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number SW: 1K0 907 044 BJ, Part number HW: 1K0 907 044 BJ.
Component: Climatronic PQ35 090 0909
Revision: 00090016 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 70E848EF63B0B4BEAD-8024
"One error found:"
01809 - Temperature flap control motor, left side (V158).
text
000 - -
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 E, HW: 3C0 937 049 E.
Component: Onboard network module H37 1002.
Revision: 00H37000 Serial Number: 00000005792965
Encoding: 008B8F2100040F0000120C000000000000097B075C
VCID: 2B529F838A169766D8-807E
Subsystem 1 - Part number: 2K1 955 119 C. Label file: DRV\1KX-955-119.CLB.
Part number: Wiper blade 160506 020 0501.
Encoding: 00038805
Address 15: Airbag
Label file: DRV\1T0-909-605.lbl
Part number SW: 1T0 909 605 C. Hardware: 1T0 909 605 C.
Part number: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial Number: 0038BD0JSGAM
Encoding: 0012338
VCID: 3566B9FB5C52D196BE-8060
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 BC, Hardware: 1K0 953 549 BC.
Component: Steering column module 035 0070.
Encoding: 0000042
VCID: 74E044FF17A8889E49-8020
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 1T0 920 872 F
Component: COMBINATION INSTRUMENT VDD 4312
Encoding: 0007101
Operating number: WSC 00011 888 06946
VCID: 377AB3F3465E2386AC-8062
Address 18: Auxiliary heater
Label file: DRV\1K0-815-071.clb
Part number: 1K0 815 071 R
Component: Auxiliary Heater 050 2302
Revision: 00050000 Serial Number: 09009839000000
Encoding: 0000011
VCID: 346084FF5728C89E89-8060
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530-V1.clb
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120
Revision: H10 Serial Number: 28001065080258
Encoding: 3D3F13C8078002
VCID: 2A5C9A8785EC8E6E23-807E
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO VDD 4312
Address 37: Navigation
Label file: DRV\1K0-035-191.lbl
Part number SW: 1K0 919 887 K, HW: 1K0 035 191 E.
Component: J401 0111
Revision: 00014000 Serial Number: VWZ1Z2F6247816
Encoding: 0023200
VCID: 418EDD2B189A6D3612-8014
Two error codes found:
01044 - Control unit incorrectly coded.
text
000 - -
Environmental conditions:
Error status: 00000011
Error priority: 3
Error frequency: 1.
Lost Count: 131
Mileage: 228,778 km
Time: 0.
Date: 2000.00.00
Time: 6:39:48 PM
00003 - Control unit.
014 - defective
Error status: 00000001
Error priority: 3
Error frequency: 1.
Lost Count: 142
Mileage: 122,254 km
Time: 0.
Date: 2000.00.00
Time: 13:11:43
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN2.lbl
Part number: 1T0 959 701 B
Component: Door seal 024 2301
Encoding: 0000181
VCID: 3664BEF74154DA8EB7-8062
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 L
Component: EPS_ZFLS, Class 071, H07, 1806.
Address 46: Comfort System
Label file: DRV\1K0-959-433-MAX.clb
Part number SW: 1K0 959 433 CB, HW: 1K0 959 433 CB.
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial Number: 00000000000000
Encoding: 009002085103087F2D06840560084F01E0BC00
VCID: 72EC42E76DBC86AE5B-8026
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE (not mounted)
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN2.lbl
Part number: 1T0 959 702 B.
Encoding: 0000181
Address 56: Radio
Part number SW: 1K0 035 153 H, HW: 1K0 035 191 E.
Component: R 0111
Encoding: 0023200
VCID: 254669BBECF2A1160E-8070
text
000 - -
Error priority: 3
Error frequency: 1.
Lost Count: 131
Mileage: 228,778 km
Time: 0.
Date: 2000.00.00
Time: 6:39:48 PM
014 - defective
Error priority: 3
Error frequency: 1.
Lost Count: 142
Mileage: 122,254 km
Time: 0.
Date: 2000.00.00
Time: 13:11:43
Address 62: Door electrics, left/right. Label file: DRV\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E
Component: Door seal 021 2428
Encoding: 0000144
VCID: 326C82E7AD3CC6AE9B-8066
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
VCID: 336287E35226CFA690-8066
Address 77: Telephone Label file: DRV\1K0-035-729-UNI.lbl
Part number: 1K0 035 729 E
Component: CIB PAH HW 203 SW 0308.
Coding: 0000364
End----------------------------(Duration: 02:29)-----------------------------
Translated on 30-07-2026, 13:29.
Post31-01-2023, 23:09    Subject: DPF Not Regenerating: Causes & Fixes Quote
Why is the DPF not regenerating
Translated on 30-07-2026, 14:06.
Hsk1816
Post31-01-2023, 23:39    Subject: DPF Not Regenerating: Causes & Fixes Quote
Hello, thank you for the suggestion. I have also read the article. I can rule out the camshafts because the engine is in its original condition. Regarding the instructions on how to regenerate the particulate filter, I have also read them and there are no objections now. Is there anything else that might be worth checking?
Translated on 30-07-2026, 14:07.
vw-doka
Rüdi and E30_V8 likes this.
Post02-02-2023, 10:19    Subject: DPF Replacement: VW Touran Repair Guide Quote
The link was about my vehicle. During the cylinder head replacement, due to worn camshaft bearings, I installed a well-maintained shaft. That was a fatal mistake. The shaft came from a vehicle without a DPF (Diesel Particulate Filter). Please read the article carefully again; these engines have problems with worn cam lobes in the camshaft area. The lobe rises, has a nearly straight section of 1.5 cm, and then continues. This flat section is where approximately 10% more fuel is injected to achieve a DPF temperature above 700 degrees Celsius. Due to the pressure from the pump elements, significant wear occurs on the cam lobes.
Your diagnostic scan says everything is okay, but this is a mechanical issue that the control unit can't record. You will probably need to remove the valve cover for inspection.
I hope I'm right, good luck.
Ralf
P.S. It's been running perfectly for 10,000 km and the regenerative braking system is working as it should.
Translated on 30-07-2026, 14:09.
Hsk1816
Post02-02-2023, 10:36    Subject: DPF Replacement: Volkswagen Touran Repair Quote
Okay, that makes sense. I still have everything in its original condition, but if there are indeed problems with the camshaft wearing out in these engines, it might also explain why the oil level rises so quickly, even though I drive 100 km per day.
I'll stop by today. Please take a picture if you're not sure whether it's locked or unlocked.
Thank you.
Translated on 30-07-2026, 14:11.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Webasto Thermo Top T: Water Pump Replacement & Leaks? Transmission, Chassis, Body & Interior
No new posts Touran, first registration 6/10, engine code BLS, auxilia... On-Board Diagnostics (OBD)
No new posts Starter Motor Touran BRU Diesel Engine Technology
No new posts VW Touran 2.0 TDI: Stuttering/Jerking Problem On-Board Diagnostics (OBD)
