Hello everyone,
I recently took my Audi 80 Avant 1.9 TDI 1Z to a workshop for a wheel alignment.
The reason was that I had the two axles overhauled two years ago, but they were only roughly adjusted and installed.
I had adjusted the rear axle according to the manufacturer's specifications.
Furthermore, I installed a KW V1 coilover suspension system and adjusted it to a ride height of 320mm.
For the measurement, I drove with new tires
What do you think about the set values?
Following the values, the collapse was not touched
Can this be adjusted on a wheel alignment machine without the special tool?
Almost 1.5 degrees is quite a bit, isn't it?
Thank you in advance for your feedback.
