Speedometer Failure 1Z: Causes & Fixes
Burli
Post17-02-2004, 23:54    Subject: Speedometer Failure 1Z: Causes & Fixes Quote
Has anyone experienced the phenomenon where, when accelerating more forcefully, the speedometer needle goes to zero, and then returns to the original speed when you release the gas pedal icon_question.gif?
Unfortunately, I haven't been able to read the error codes yet.
The motor is running normally, with no error messages or similar issues.
The first time, I thought I was just hearing things, but now it's happening more and more often.
Vehicle: Volkswagen Passat, 1.9 TDI engine (1Z), manufactured in 1995, 66 kW.
Thank you.
Burli.
Translated on 06-09-2026, 14:23.
Gremlin
Post18-02-2004, 0:07    Subject: Speedometer Failure 1Z: Causes & Fixes Quote
Please check the speed sensor on the transmission, as well as its connector and wiring.
CU Gremlin.
Translated on 06-09-2026, 14:24.
Burli
Post18-02-2004, 0:09    Subject: Speedometer Failure 1Z: Causes & Fixes Quote
Hi Gremlin,
I've also considered the donor, but why only when accelerating more strongly? It's not noticeable in gentle mode.
Burli.
Post18-02-2004, 0:17    Subject: Speedometer Failure 1Z: Causes & Fixes Quote
If the cable has a loose connection that only causes it to go "open" when there's "force pulling back" (i.e., when accelerating), then you'll experience this effect.
Burli
Post18-02-2004, 0:19    Subject: Speedometer Failure 1Z: Causes & Fixes Quote
Unlikely, but unfortunately not entirely impossible.
'Where exactly is the sensor located on the transmission? I think it's an inductive sensor, or?'
Burli.
Translated on 06-09-2026, 14:25.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tachoausfall bei 4er Golf TDI, Tankanzeige schwankt Transmission, Chassis, Body & Interior
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
