Steering Wheel Crack Noise: Causes & Fixes
kakamido
Post08-08-2004, 18:38    Subject: Steering Wheel Crack Noise: Causes & Fixes Quote
'On our Passat 35i, manufactured in October 1996 (240,000 km), there's a cracking sound when steering, especially when turning the wheel fully, such as when parking. However, it only happens once when turning in one direction, and a second time when turning in the other direction, although it doesn't require a full turn in that direction. The same thing happens in the other direction as well.'
'This cracking sound has recently started occurring occasionally when steering at higher speeds.'
I replaced the front wheel bearing on the passenger side; it was worn out.
In addition, new shock absorbers have been installed all around, and new strut mounts are in the front.
Okay, here are the questions:
1. It could be due to the new wheel bearing.
2. Could it be the steering gear? And if so, how does a defective steering gear manifest itself, or how can I check it?
Thank you for your help.
Translated on 30-10-2026, 6:47.
Manuel Thomas
Post08-08-2004, 21:09    Subject: Steering Wheel Crack Noise: Causes & Fixes Quote
The steering mechanism can even be adjusted.
One person slowly tightens the adjustment screw, while the other steers within a range of approximately 30 degrees around the steering axis without power steering assistance!
Manuel.
Translated on 30-10-2026, 6:49.
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Knuckle Noise: Causes & Fixes Diesel Engine Technology
No new posts Clicking Noise Steering Belt Drive, Polo 9N3 Diesel Engine Technology
No new posts Noise when steering/accelerating after transmission repla... Diesel Engine Technology
No new posts Sharan 7N: Valve Block Crack Repair Transmission, Chassis, Body & Interior
