ESP - active in left turns after wheel bearing replacement
Brösel
Post05-08-2004, 8:26    Subject: ESP - active in left turns after wheel bearing replacement Quote
ESP - active in left-hand curves after wheel bearing replacement - what now?
Uwe
Post05-08-2004, 9:29    Subject: ESP - active in left turns after wheel bearing replacement Quote
I think the opposite is true. The work likely caused the sensor or sensor ring on the wheel to become coated with brake dust, which is distorting the signal.
I've had similar problems with the ABS before. Just remove the sensor and blow everything out with compressed air. I can't imagine any other cause. Possibly a damaged toothed wheel due to external force?
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
RalfBru
Post05-08-2004, 10:22    Subject: ESP - active in left turns after wheel bearing replacement Quote
'I've experienced something similar with the ABS system before. When changing the wheel bearings, there's just too much dirt and debris in the air, and it probably ends up settling on the ESP sensor. Please definitely post what the ultimate cause turned out to be...'
I find the statement from your workshop that it is now cleaner than the other one to be unbelievable. If they try to dismiss you like that, and it turns out that statement is not true, I would suggest you find a different workshop. icon_surprised.gif
Ralf
donalexo
Post05-08-2004, 11:25    Subject: ESP - active in left turns after wheel bearing replacement Quote
Hello Brösel,
During the wheel bearing replacement, the toothed ring (tone ring) may also have been damaged (keyword: runout).
When I modified my suspension in May, I was also dismayed to discover a completely crumpled sensor ring on the left front wheel. This one was completely crushed icon_evil.gif in the workshop last year during a wheel bearing replacement.
Fortunately, the deviation from the planned process seems to be still within the acceptable icon_biggrin.gif.
Alex.
Touran 1.9 TDI, EZ 09/2004
RalfBru
Post05-08-2004, 12:58    Subject: ESP - active in left turns after wheel bearing replacement Quote
Okay, in my case with the ABS, after starting the car, the warning light initially didn't illuminate. Then, after several braking maneuvers, the ABS would unpredictably engage in every braking process (which was quite a fun icon_lol.gif) until the control system realized something was wrong and completely deactivated the ABS. Only after the complete deactivation did the warning light illuminate permanently. So, I suspect that your ESP isn't completely deactivating itself, but rather only indicating malfunctions. If the lamp were to finally light up, you could at least approach the next left-hand curve in a somewhat normal way... icon_confused.gif
Uwe
Post05-08-2004, 13:33    Subject: ESP - active in left turns after wheel bearing replacement Quote
Brösel wrote:
What about the def. If the donor is connected, would an error message be created and the ESP light constantly illuminate, or ???
Yes and no. If the control unit receives an implausible signal, the ESP will be deactivated, and the warning light will illuminate.
This happens, for example, when a sensor is broken or the power supply cable has a loose connection.
However, if the control unit receives a signal that is only slightly distorted due to a few missing pulses, this malfunction can occur as long as the incorrect signals remain within the acceptable tolerance range.
Therefore, it is very likely that the donor crown you mentioned is responsible for this issue.
Uwe
RalfBru
Post08-09-2004, 11:18    Subject: ESP - active in left turns after wheel bearing replacement Quote
Hello Brösel,
Could you please let me know what the ultimate cause of the problem was, or are you still dealing with it?
Ralf.
thefirefly1
Post30-07-2005, 16:09    Subject: ESP - active in left turns after wheel bearing replacement Quote
Hi!
So, I haven't had any problems with ESP yet, and I don't even have any icon_wink.gif.
The gyroscope sensor does have moving parts, but it's only a few hundred nanometers in size, so I don't think you can hear it. For a cross-axis accelerometer, it's essentially the same thing...
So, the noises must be coming from a different part.
chli1976
Karma: +185 / -0   Thank you, like it!
Post26-08-2005, 15:53    Subject: ESP - active in left turns after wheel bearing replacement Quote
You will probably need a login code for that.
vagtuning
Post27-08-2005, 14:52    Subject: ESP - active in left turns after wheel bearing replacement Quote
What interface are you using, and which version of VAGCOM?
Please share the data that the ECU (Engine Control Unit) outputs (part number, etc.).
VAG testers are actually unable to block anything.
I once had something similar; everything looked perfectly fine with my eyesight.
A hairline crack in the rotor caused the error. We found it by connecting the sensor to an oscilloscope... the waveform looked good, but there was always a small spike in it. This wasn't present with the other sensors, so we removed everything, installed a new rotor, and checked again. The spike was gone. Assembled and driven - the error has never occurred again.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Radlagertausch...... was darf das kosten ? Transmission, Chassis, Body & Interior
No new posts The ESP light is flashing and the car is braking in certa... Transmission, Chassis, Body & Interior
No new posts *PERMANENT* Error 37, ban period active. On-Board Diagnostics (OBD)
No new posts High beam permanently activated, VW Caddy Electrical Systems, Vehicle Electronics, Multimedia
