RNS2 Installation: Control Unit Errors
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
poppel
Karma: +1 / -2   Thank you, like it!
Post11-03-2007, 0:46    Subject: RNS2 Installation: Control Unit Errors Quote
I've been repeatedly finding the following error in the error memory of my T5 (year 2007) after installing the RNS2.
Everything is working fine, despite this error message.
Saturday, March 10, 2007, 17:11:03.
VAG-COM Version: RKS 607.3-UD
VAG BIGGER.
Control unit part number: 7L6 919 887.
Component and/or Version: Navigation 0101.
Software coding: 0000002
Workshop code: WSC 00000.
"One error found:"
01317 - Control unit in the instrument panel carrier (J285)
004 - No signal/communication.
Does anyone have any ideas?
Translated on 06-10-2026, 11:15.
Ross-Tech-Support
Post11-03-2007, 3:53    Subject: RNS2 Installation: Control Unit Errors Quote
What do the data blocks indicate?
Translated on 06-10-2026, 11:16.
vagtuning
Post11-03-2007, 11:35    Subject: RNS2 Installation: Control Unit Errors Quote
I am particularly interested in MWB models 80 and 81.
And please post the self-diagnosis messages from address 56 (Radio).
Or a complete car scan, that would be best.
poppel
Post11-03-2007, 21:50    Subject: RNS 2 Scan: Fast and Accurate Scanning Quote
Here's the car scan:
Okay, I don't have a standing heater, and only the front speakers work.
Sunday, March 11, 2007, 5:10:29 PM.
VAG BIGGER.
Vehicle type: 7H - VW Transporter T5.
Scan: 01 02 03 08 09 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56 57
6E 76 77 78 7D
Chassis number: WV2ZZZ7HZ7
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 17: Combination instrument.
Part number: 7H0 920 861 E
Component: KOMBI+WEGFAHRSP VDO V02
Encoding: 01113
Workshop code: WSC 02756.
WV2ZZZ7HZ7H110009 VWZ7Z0G4990816
No errors found.
Address 18: Auxiliary heating.
Part number: 7H0 815 071 G
Component: Auxiliary heater 0210
"One error found:"
00664 - Fuel level indicator.
002 - lower limit exceeded.
Address 37: Navigation.
Part number: 7L6 919 887.
Component: Navigation 0101
Encoding: 0000002
"One error found:"
Address 56: Radio.
Part number: 7L6 035 186 A
Component: Radio 0101
Encoding: 0001445
6 errors found:
00879 - Connections for front right speakers.
007 - Short circuit to ground - Intermittent.
00880 - Connections to rear left speaker.
011 - Interruption.
00881 - Connections to the rear right speaker.
011 - Interruption.
00858 - Connection between the ZF (intermediate frequency) output of the radio and the antenna amplifier.
011 - Interruption.
01042 - Control unit not coded.
000 - -
Ende.
Translated on 06-10-2026, 11:22.
vagtuning
Post11-03-2007, 22:48    Subject: RNS2 Installation: Control Unit Errors Quote
Please re-encode the radio (channel 56) to 00421 and see if any messages can be deleted. Then, please provide a COMPLETE scan, as my previous explanation might have been unclear.
Translated on 06-10-2026, 11:27.
poppel
Post11-03-2007, 22:51    Subject: Scan: How to Scan Documents & Images Easily Quote
I only used the scan to make it easier to see the details without any errors. Or am I doing something wrong, or have I misunderstood something?
Autoscan > T5 ...
Translated on 06-10-2026, 11:28.
vagtuning
Post11-03-2007, 22:57    Subject: RNS2 Installation: Control Unit Errors Quote
Well, it's generally correct, but it makes sense when someone is asking for a complete log, and that includes the STG entries, even if no error was detected in them.
Besides that, once the errors are fixed, you should bring it to the attention of your dealer that a significant update for the navigation system is available, which they will likely be happy to install for you.
poppel
Post11-03-2007, 23:01    Subject: Autoscan: Complicated? Easy with [Your Brand/Product] Quote
VAG BIGGER.
6E 76 77 78 7D
Address 01: Engine.
Part number SW: 070 997 016 K, Hardware number: 070 997 016 K.
Component: R5 2.5L EDC G000AG 0859
Encoding: 0001075
No errors found.
Self-test: 0 0 0 0 0 0
Address 02: Transmission.
Part number SW: 09K 927 750 L, Hardware number: 09K 927 750 L.
Component: AQ 250 6F, 0981.
Encoding: 0000072
No errors found.
Address 03: ABS Brakes.
Part number SW: 7H0 907 379 R, HW: 7H0 907 379 R.
Component: ESP MK25E1 0104
Encoding: 0000555
No errors found.
Address 08: Heating/Climate Control.
Part number: 7H0 820 045 AM
Component: CLIMA/AC 0303
No errors found.
Address 09: Body Control Module.
Part number: 7H0 937 049 AA
Component: BORDNETZ SGVER 1.0, 2001.
Encoding: 0000103
No errors found.
Address 15: Airbag.
Part number: 1C0 909 605 A
Component: 3C AIRBAG VW51, Part Number: 0010.
Encoding: 13123
No errors found.
Encoding: 01113
WV2ZZZ7HZ7 VWZ7Z0G4990816
No errors found.
"One error found:"
Address 19: CAN Gateway.
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
No errors found.
Encoding: 0000002
"One error found:"
Address 46: Comfort System.
Part number: 7H0 959 433 B
Component: CXL Comfort Device 0004.
Encoding: 00025
No errors found.
Address 56: Radio.
Encoding: 0001445
6 errors found:
011 - Interruption.
011 - Interruption.
011 - Interruption.
000 - -
Address 76: Parking assist.
Part number: 7H0 919 283.
Komponente: Parkingsyst. T5 T5N 401
Encoding: 01137
No errors found.
"End"
"The sun is shining brightly, and the birds are chirping cheerfully. A gentle breeze is blowing through the trees, and the leaves are rustling softly. It's a beautiful day to be outside."
Translated on 06-10-2026, 11:40.
poppel
Post11-03-2007, 23:05    Subject: RNS: What is RNS? Meaning and Definition Quote
As I mentioned before, I installed the navigation system.
I wasn't aware that there were updates available for it.
I don't need to ask my dealer for help; he's not capable of assisting me.
I shouldn't have ordered the car, which is only three weeks old, to be delivered there.
WHERE else can I order the update?
Translated on 06-10-2026, 11:50.
vagtuning
Post11-03-2007, 23:14    Subject: RNS2 Installation: Control Unit Errors Quote
Only a dealer can provide you with that; you can't order it directly.
Besides that, I would also advise against it if you don't have the necessary knowledge and equipment (like an external, sufficiently powerful charger) available.
If the device malfunctions during the process, then more than possibly 50 euros, which a dealer might want for the flashing process, will be lost icon_wink.gif. You know how much the device cost.
Translated on 06-10-2026, 11:51.
poppel
Post11-03-2007, 23:22    Subject: RNS Update: How-to & Troubleshooting Quote
With my RNS DVD version, I just had to insert the update CD and it started working.
Is the RNS CD version updated via the VAG Service System, or can it also be updated while installed using a CD?
Where can I find information about possible updates?
Translated on 06-10-2026, 11:52.
vagtuning
Post11-03-2007, 23:30    Subject: RNS2 Installation: Control Unit Errors Quote
It works exactly the same way as the DVD version: insert the CD, press the button, and wait for about three-quarters of an hour.
If the battery voltage drops while it's happening, then it's toast icon_wink.gif.
Translated on 06-10-2026, 11:53.
poppel
Post11-03-2007, 23:36    Subject: RNS: What is RNS? Meaning and Definition Quote
Okay, now I understand what it was about.
As always, when updating, make sure to use a sufficiently powerful and stabilized power supply.
Similar to all firmware updates.
Thank you.
Will that solve my problem?
What is different about encoding 00421? Where did you get that number?
And.
Translated on 06-10-2026, 11:54.
vagtuning
Post11-03-2007, 23:46    Subject: RNS2 Installation: Control Unit Errors Quote
Okay, right now the navigation system still has the coding from the donor Touareg, which is obviously completely wrong. Try it out, then clear the memory and see which errors are re-entered.
The update should definitely be installed, as it increases the device's reliability, speed, and overall performance.
In addition, there are some 'error'-type memory entries that may occur.
Why conjure up problems that can be ruled out immediately?
Translated on 06-10-2026, 11:55.
poppel
Post11-03-2007, 23:51    Subject: RNS: What is RNS? Meaning and Definition Quote
Okay, I'll try it tomorrow.
The message about the dashboard deployment confused me. If there were no communication possible, wouldn't the information like steering angle and speed also not be displayed on the navigation system?
Do I also need to reprogram the RNS DVD version in the Touareg?
Translated on 06-10-2026, 11:56.
vagtuning
Post11-03-2007, 23:54    Subject: RNS2 Installation: Control Unit Errors Quote
Did you install the CD player from the Touareg into the T5, and the DVD player from the T5 into the Touareg, or something else?
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts GRA errors after AHK installation, Roomster 2010 On-Board Diagnostics (OBD)
No new posts vw Polo 6C Front Assist error after trailer hitch install... On-Board Diagnostics (OBD)
No new posts GRA Supplemental Restraint System (SRS) Installation Erro... On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
